When two materials collide or rub against each other
  • Thread starter kenny1999
  • Tags
    Materials
In summary, when two materials of the same or different type collide or rub against each other, they can lose particles or atoms at the molecular level, which can lead to wear and tear. This can also cause welding at asperities and introduce defects in crystalline materials. More information on this topic can be found by searching terms such as tribology and theories of friction.
kenny1999
235
When two materials of the same type or different type collide or rub against each other (either slightly or vigorously) that happens around us every day everywhere
At the molecular level, do they lose any particles/atoms because of the collision?
Chemistry news on Phys.org
Yes. Sometimes there is welding at the molecular level. The subject is too large to cover in a post, so start by searching tribology. Another search term is theory (or theories) of friction.
One mechanism of wear is welding at asperities, followed by tearing off microscopic pieces, which show up as wear particles.
Likes kenny1999
Hi. It's easy to imagine that any wear or breakage will cause loss of atoms / particles that we can easily observe and understand with naked eyes. I hope to know about ANY other collision of lesser extent that does not cause wear or breakage
And if the material is crystalline, defects such as crystal dislocations can be introduced at the surface and increase the chemical activity in a process known as mechanochemical activation.
Related to When two materials collide or rub against each other
1. What causes materials to collide or rub against each other?
Materials collide or rub against each other due to a force acting on them, such as gravity or an external force applied by an outside source.
2. What happens when two materials collide or rub against each other?
When two materials collide or rub against each other, they can produce heat, sound, or other forms of energy. This can also result in changes to the physical properties of the materials, such as wear and tear or deformation.
3. How does the type of material affect the collision or rubbing process?
The type of material can greatly affect the collision or rubbing process. Materials with different textures, hardness, and composition will produce different levels of friction and result in varying levels of wear and tear.
4. Can materials collide or rub against each other without any friction?
No, friction is a necessary component of materials colliding or rubbing against each other. Without friction, there would be no resistance between the materials and they would simply pass through each other.
5. How does the speed of the materials affect the collision or rubbing process?
The speed of the materials can greatly impact the collision or rubbing process. Higher speeds can result in more force and energy being produced, which can lead to more significant changes in the materials involved.
  • Atomic and Condensed Matter
  • Astronomy and Astrophysics
  • Differential Equations
