When unsuccessfully trying to lift a weight, where does my energy go to?
In summary: It's tiring to walk down stairs! Or to walk downhill. Whereas, on a bike you can go downhill without expending any energy.Yes, it's true that on a bike you can go downhill without expending any energy - you are just riding on the momentum of the bike. But if you tried to do the same thing on a stair, you would expend energy.
khan
Let's say I am strong enough to lift a 100 kg dumbbell, but not strong enough for a 200 kg one.
If I lift the 100 kg dumbbell, I suppose the chemical energy of my body tranforms into the potential energy of the lifted dumbbell. Suppose I'm trying to lift the 200 kg one. I'm pulling as hard as I would be if I were lifting the 100 kg one, so the loss of my energy should be the same. But the dumbbell stays on the ground so there is no gain in its potential energy. My question is, where does my energy go? It seems to me that on my part, nothing changes, I'm pulling as hard as I can in both cases, sweating, pressing the floor, whatever. So what accounts for the difference in the change of potential energy in the case of the lighter dumbbell and no change of potential energy in the case of the heavier one?
Likes khan
The human body is not a particularly efficient machine. And its efficiency is not even constant. The energy goes into heating your muscles. If you are not budging the weight, the efficiency is 0%. If you are climbing down stairs, your efficiency even goes negative. You burn energy absorbing energy.
Likes khan, russ_watters, hutchphd and 1 other person
I wonder how successful you would be at body-building if you worked only with weights that you couldn't move?
Likes rude man, khan, sophiecentaur and 2 others
Isometrics was a muscle building technique advocated by Charles Atlas in the 50's
I immediately thought of Charles Atlas and Dynamic Tension, but when I checked, that is not quite isometric exercise. Dynamic Tension was 100% inefficient use of muscles, since they worked against each other, but there was movement.
Isometric exercises are supposed to build muscle strength, so one might think they'd increase muscle mass as well.
Back to OP. The phenomenon is not unusual. If you used a simple DC motor powered from a fixed voltage (and other types) to lift a load, when you exceed stall torque, it actually consumes more power than when lifting a load, but all the power goes into resistive heating of the windings and none into useful work.
Another simple eg. of inefficiency: you can block the hose of a vacuum cleaner so that it can no longer do useful work moving air. Again all the electrical energy then goes int heat. What fascinated me about this was that the motor, far from stalling, speeds up and draws less electrical power, but still ends up with 0 efficiency as an air pump.
Likes khan, Lnewqban, hutchphd and 1 other person
I'm not sure if I understand you. Are you trying to say that the energy that would go into lifting the weight goes instead into heating my muscles? So my muscles are heating more if I'm not unable to lift the weight? That would explain where the energy goes to, but seems quite unintuitive...
And what exactly do you mean by "you burn energy absorbing energy"?
Thanks!
  • Sad
Likes Motore
Thanks!
Likes khan
Thanks!
Simply tensing your muscles involves individual fibers repetitively clenching and releasing to produce the desired tension. Regardless of whether any motion results, this consumes chemical energy.
If you descend a flight of stairs, this still happens. So your fibers are being intermittently tensed, consuming chemical energy even while the descent of the stairs is providing mechanical energy.
Energy is still conserved, of course. The excess shows up as heat.
Likes khan
Thanks, these are great examples!
So you think that my muscles are heated more if I'm trying to lift the weight but am not able to? That would explain where the energy goes. But it would also mean that the more work you do, the less you sweat :) It makes sense, but still seems weird...
Were you planning to lower the weight after you lift it? If so, does it really matter that you moved it? The work done on the weight was zero.
Likes russ_watters
It is tiring because I'm slowing my descent. If I just fell from the stairs the potential energy I would loose would got to my kinetic energy and then to the vibrations of the floor. If I'm walking down I move more slowly and don't stomp so much, so some of the potential energy I loose somehow stays inside me. Is that right? If so, what is the form of the energy? Is it heat again? And only heat?
Well, I didn't go that far in my planning :)
But thanks so much, I think I get it now. The answer seems to be just heat, heat, and heat again.
All things being equal, that should be the opposite of tiring. That should "charge your batteries".
But muscles do not do regenerative braking. So your batteries do not get recharged.
Yes, it all goes to heat. The chemical energy you consume keeping your muscles tense and the potential energy that is used up both go into heating your body.
Likes russ_watters and khan
We're not biologists here, but I don't think that's correct. I think the energy/heat dissipated is related to the force generated and largely independent of the mechanical power generated.
It's also worth noting that for most exercises the net mechanical output work is zero anyway. You lift a weight and then you put it back down where it started.
Likes jbriggs444
I am in agreement here. As a practical matter, any real effect is likely to disappear into the experimental noise.
A quick trip to Google suggests a figure of as much as 30% for aerobic efficiency of a cyclist (counting just the delta from unloaded versus loaded cycling). Reference here. The number is higher than I'd expected.
If one were able to measure for heat gain in the body against O2 consumption, the result would presumably be that the work produced moving the bike is indeed subtracted from the heat gained in the body. Anything else would violate energy conservation.
[The experiment here is not directly on point. It is comparing loaded versus unloaded muscle use rather than loaded immobile versus loaded moving. The figure of merit I was after was efficiency. For that, it is a good reference]
Likes russ_watters
Related to When unsuccessfully trying to lift a weight, where does my energy go to?
1. Where does the energy come from when I lift a weight?
The energy needed to lift a weight comes from the chemical energy stored in your body. This energy is released when your muscles contract and work against the force of gravity.
2. Why do I feel tired after unsuccessfully trying to lift a weight?
When you are unable to lift a weight, your muscles are still using energy to try and lift it. This results in a build-up of lactic acid, which causes fatigue and muscle soreness.
3. Does the weight gain energy when I try to lift it?
No, the weight does not gain energy when you try to lift it. The energy is coming from your own body and is being used to overcome the force of gravity and move the weight.
4. Can I conserve energy when lifting a weight by using proper form?
Yes, using proper form while lifting a weight can help conserve energy. This is because proper form allows your muscles to work more efficiently, reducing the amount of energy needed to lift the weight.
5. Where does the energy go when I successfully lift a weight?
When you successfully lift a weight, the energy is used to overcome the force of gravity and move the weight. Some of the energy is also converted into heat, which is why you may feel warm after a strenuous workout.
21K
  • Mechanics
  • Mechanics
