Ocata
- 198
- 5
When Voltage is oscillating (A/C), then in a simple circle with steady resistance, the current will be proportional to the voltage. When voltage increases, current will increase. And when voltage decreases, voltage will decrease. Is it also true that in a simple circuit with constant resistance, when voltage is steady (DC), then current will also be steady.
P.S.
by "steady," I mean a horizontal line on the graph.
V = IR
Supposing this is correct based on observing that graphs of AC voltage (represented by some sort of sine function) are usually accompanied by current represented by a sine function. I have not seen an a/c voltage graph accompanied by a steady horizontal line for current.
Thus I assume that if current is to remain proportional to a steady resistance, the current has to maintain the same "flow pattern" (perhaps different amplitude, but same frequency and phase etc) on the graph as voltage.
Thanks
