- #36
Ken G
- 554
That is an important issue because it properly focuses our attention where it needs to be: what is happening to the heat. There are really two separate considerations that are required to have core collapse. The first is there even at zero temperature, which asks, is there a hydrostatic equilibrium at all for the electrons, or is gravity too strong? That's the Chandra mass. The second is, when contraction starts, will there be enough gravitational energy released to renew the pressure support? That's a rather different question, because it does not assume the temperature is zero, and if the temperature is not zero, adiabatic gravitational contraction will increase the temperature. Since the contraction is neither adiabatic nor at zero temperature, attention shifts to what happens to the heat. So that's where we must look for thermal instability as the necessary cause of core collapse.PeterDonis said:It can support itself if kinetic pressure (and therefore temperature) is sufficiently high. But that means fusion temperature, not just "not zero" temperature. What happens when the temperature is well below fusion temperature but well above zero temperature?
What I was saying was going back to the OP where we add mass very slowly, say a particle at a time. If we make the simplifying assumption used in the derivation of the Chandra mass, that the temperature is zero, what we are saying is that the temperature constantly stays at zero as we add mass, particle by particle. There is obviously always a force balance in that situation, right up until you have a black hole (or at least GR-type instabilities very near to the creation of a black hole). So there's no core collapse there because the processes that lead to thermal instability, like photodisintegration and the Urca process, don't happen at zero temperature. This is why I'm saying that the loss of force balance has to do with thermal processes that remove heat, and do so in a runaway kind of way that ultimately leads to thermal timescales shorter than the force-balance timescale, and that's what produces the free fall. The basic assumptions that go into the Chandrasekhar mass will not give a loss of force balance when the mass is added slowly enough, so that's why the Chandra mass calculation is just a benchmark for the mass scale of interest, not a physical description of the core collapse process.I disagree, but I think the disagreement is more about the equation of state than about the thermal issue (see further comments below). I agree that the thermal timescale is an important factor if a hydrostatic equilibrium is possible; but I think we disagree about when a hydrostatic equilibrium is even possible.
None of my argument relies on that. The equation of state of the neutrons is of no importance, because the equivalent to the "Chandra mass" when dealing with neutrons is higher than for electrons. Hence, the EOS for neutrons is never part of the explanation of core collapse, but it is part of the explanation of the completely separate process of core bounce.So what, the equation of state just magically agrees to not change until the conversion into neutrons is complete?
The object still has a structure while that process is going on, and that structure is still affected by degeneracy pressure; so the sharp drop in degeneracy pressure during the conversion process is going to affect stability. Whether you are willing to call that a "change in the equation of state" is a matter of words, not physics. How much it affects it will depend on how much degeneracy pressure contributes to hydrostatic equilibrium, but as above, there is a wide range of temperatures between "zero temperature" and "fusion temperature" where degeneracy pressure still contributes significantly to hydrostatic equilibrium..
Again, since the Chandra mass for neutrons is higher than for electrons, the neutron EOS never plays any role in the reasons we have a core collapse.In other words, "the index is 5/3 for nonrelativistic, and 4/3 for relativistic, except when it isn't". While this is true, it doesn't seem to be very helpful. ;)
I can only repeat, those "other forces" clearly have nothing to do with why we get a core collapse, since they oppose collapse. The effects of beta decay that matter are how they remove heat when the neutrinos escape. That is not the neutron EOS, that is the thermal instabiilty that contributes to the core collapse.As for the "other forces", which is the point, neutrons experience those regardless of temperature, and the effects on degeneracy pressure of inverse beta decay happen regardless of temperature, correct?
That is what I have been saying-- you are talking about a contributing factor to thermal instability that is the real reason for core collapse. The existence of a Chandra mass just tells you that you will have a compact object, it does not tell you that you will lose force balance along the path to reaching that compact object. So again, the Chandra mass is a benchmark for when you might get a thermal instability and a core collapse, but the actual existence of a core collapse requires analysis of the thermal instability. That's the part that answers the OP question, of why you don't just smoothly contract when you add mass slowly-- as you approach the Chandra mass, a thermal instability sets in, and at that point you don't even need to add any more mass at all.If a white dwarf contracts enough for inverse beta decay to start, it will experience a sharp drop in degeneracy pressure regardless of its temperature, so hydrostatic equilibrium will be affected even if it is hot.
