When will the hot cup of tea cool faster?
  • Thread starter TSN79
  • Tags
    Cool Hot
In summary, the conversation discusses the idea of whether clenching and releasing a cup of tea would cause it to cool faster. The person wonders if the heat would transfer more quickly to their hand than to the surrounding air, and suggests conducting an experiment with two cups and thermometers to test this theory.
TSN79
424
I just sat with a cup of tea, and started wondering about this. If the cup just sits there, the tea will cool slowly. Will it cool faster if I repeatedly clench and let go of the cup? The difference between the cup surface temp and the surrounding air is higher than than between the cup and my hand, but then again I sense that the heat will have an easier time transfering to my hand than to the air...and so I sit here wondering :) What do you think?
The root question is; is conduction at T_coffee times Flux_mass coffee less T_hand more effective than convection at T_coffee less T_air times Flux_mass air
You could actually make two cups and do the experiement. Drop a thermometer in each, and clench only one. My hunch is that the clenched one cools faster.
Related to When will the hot cup of tea cool faster?
1. Why does a hot cup of tea cool down faster than a cold cup of tea?
The rate at which an object's temperature changes is directly related to the temperature difference between the object and its surroundings. A hot cup of tea has a higher temperature than its surroundings, so it will lose heat at a faster rate until it reaches equilibrium with the colder room temperature.
2. Does the material of the cup affect how quickly the hot tea cools?
Yes, the material of the cup can affect how quickly the hot tea cools. Materials with high thermal conductivity, such as metal, will transfer heat away from the tea more quickly than materials with lower thermal conductivity, such as ceramic or glass.
3. How does stirring the tea affect its rate of cooling?
Stirring the tea can help it cool faster by increasing the rate of heat transfer. When you stir the tea, you are bringing the hotter liquid from the bottom of the cup to the surface, exposing it to cooler air and allowing it to cool down more quickly.
4. Will adding milk or cream to the tea affect its cooling rate?
Yes, adding milk or cream to the tea will affect its cooling rate. Dairy products have a higher specific heat capacity than water, meaning they require more energy to change temperature. This means that the tea with added milk or cream will take longer to cool down compared to plain hot tea.
5. Can the size or shape of the cup affect how quickly the hot tea cools?
Yes, the size and shape of the cup can affect how quickly the hot tea cools. A larger surface area allows for more heat to be transferred to the surrounding air, so a wide, shallow cup will cool the tea faster than a tall, narrow one. Additionally, a thinner cup will transfer heat more quickly than a thicker cup.
  • Other Physics Topics
13K
  • Thermodynamics
