When you can't use conservation of energy
In summary, the conversation discusses the application of conservation of energy laws and the challenges of solving problems where tension forces and multiple forms of energy are involved. It is important to carefully consider the wording of the question and to properly define the system in order to accurately use conservation of energy equations.
lonewolf219
186
I have noticed that I try to apply conservation of energy laws to solve various problems, and they don't always work. For example, this problem I'm doing now is a roll of toilet paper that drops to the floor while someone is holding the first sheet of paper.
Is it the presence of a tension force from the person holding the roll that violates conservation of energy? I keep making this same mistake
It depends what you have done.
If you can show us how you attempted to solve the problem it would help.
The exact wording of the question is also important.
Questions like this usually say things like "ignore friction" as a clue to being able to use conservation of energy.
Energy can take a number of forms, and in the question you mention there is kinetic and potential.
The kinetic energy will be both rotational (the roll spins) and translational (it drops to the ground).
Energy is always conserved. But in some cases it is difficult to measure some forms of energy.
For example:it is rather difficult to measure the energy of the sound made when a roll of paper falls on the floor.
Indeed. I could have added that in questions of this type, it's whether or not you can consider mechanical energy to be conserved.
Where you draw your 'box' is also important. Energy is conserved in a closed system. But if you let energy cross the boundary of your box (your system), then you can't rely on those equations anymore.
FAQ: When you can't use conservation of energy
Why can't conservation of energy be used in all situations?
In certain situations, energy may not be conserved due to external forces or non-conservative forces acting on the system. These forces can change the total energy of the system, making conservation of energy not applicable.
What are some examples of situations where conservation of energy cannot be applied?
Some common examples include systems with friction, systems with air resistance, and systems with external forces such as gravity or electric fields.
How do non-conservative forces affect the conservation of energy?
Non-conservative forces, such as friction, dissipate energy in a system and therefore do not allow the total energy to remain constant. This makes it impossible to apply the principle of conservation of energy in these situations.
Can energy be created or destroyed in a system where conservation of energy cannot be used?
No, energy cannot be created or destroyed in any system. However, in situations where conservation of energy cannot be applied, the total energy of the system may change due to the work done by non-conservative forces.
How can we still analyze systems where conservation of energy cannot be used?
In these situations, we can still use the principle of energy conservation to analyze changes in the different forms of energy in the system. We can also use other principles, such as the work-energy theorem or the principle of momentum conservation, to analyze the system and make predictions.
