Where are the alternators in jet planes?
  • Thread starter Charles123
  • Tags
    Jet Planes
In summary: The constant speed drive is a gearbox that sits on the outside of the engine. It is connected to the engine by a shaft, and it drives the engine fuel and oil pumps, etc.
Charles123
132
In jet aircrafts where are the alternators, how are they connected to the jet engines? Is it using belts? Are they on the wings?
Thank you
Regards
On Boeing 707 they were on the engines through a variable speed drive so they can be synchronized.
Somebody may have newer infromation.
Thank you for your answer. Can you develop it? What do you mean by "on the engines"?
regards
Aircraft engines have a gear driven power takeoff for accessories
the alternator will be bolted to the engine wherever thay put the accessory package
on old Continental piston engines it was at rear between magnetos
i suspect it's nearer middle of jet engines, probably pkruse would know better than i.
check these two images
http://www.hyperneticsltd.com/photos/pma_2.jpg
and
http://avstop.com/ac/apgeneral/alternator.html
You mean inside the jet engines?
Inside the engine pod but outside the engine.
Probably one of those appendages surrounding engine just left of center in above image.
A real turbine guy would know which one. Sorry, i don't.
PrattWhitney site should have better details at their site..
See anything here looks like an alternator?
http://www.pw.utc.com/media_center/images_library/images/pw400094_1_high.jpg
I dont... Is it belt driven?
no, aircraft design is for extreme reliability. They'll be direct driven through variable speed drive as described in second link above.
As i said I'm not a turbine guy so can't point to the alternator.
Search a while and you'll find service manuals for gas turbine engines.
Thank you for your answers!
I am reading some things about the constant speed drive unit for the alternator. I can't understand how the engine shaft will connect to a constant speed drive unit gear that then will link to the alternator, since these will have to be outside the engine. How can the engine remain airtight in the middle if it has some sort of gear to connect to the outside?
I looked in those P&W cutaways for a gear driven shaft for auxilliaries, couldn't find one with cursory search.
But it's easy to seal around a shaft, every automobile motor has at least two.
here's a video for an old jet, F86 era acccessories on front end.
and here
http://en.wikipedia.org/wiki/Accessory_drive
and from a GE glossary
Accessory Drive
The accessory drive section is attached to the outside bottom or side of the engine and is where all the mechanically-driven components are mounted to the engine. This section takes mechanical energy from the engine to power the engine and aircraft accessories mounted to the accessory gearbox.
http://www.geaviation.com/education/vocabulary.html
Spend some time at that site it's interesting.
http://www.geaviation.com/engines/commercial/genx/2b_fett.html
Modern jets usually have a separate auxiliary power unit (APU) to generate electrical pwer. This is usually a small gas turbine whose only function is driving a generator. They are usually located in the tail of the aircraft.
This has the advantage that the aircraft can operate under its own power on the ground, without the main engines running. It also removes the problem of running the generator at constant speed when the main engine speed changes.
There are reliabilty consderations that have to be taken into account. The "ultimate backup generator" can be literally a wind turbine that is normally stowed in inside the wing or fuselage and deployed when all else fails. http://en.wikipedia.org/wiki/Ram_air_turbine
The variable speed drive is not in the pressurized part of the engine. There is usually a radial drive shaft (with a gear drive) between one of the engine rotors and a unit mounted on the outside of the engine casing. The constant speed drive would be inside the external unit. This also drives the engine fuel and oil pumps, etc.
Thank you both for your answers. jim hardy those are nice links, thank you.
The "APUs are also used to run accessories while the engines are shut down." from http://en.wikipedia.org/wiki/Auxiliary_power_unit. Does this mean that during flight they have no use?
Also I am trying to understand how the constant speed drive systems to link the engine to generator work. I am finding very little information, useful links just these:
http://www.k-makris.gr/AircraftComponents/CSD/C.S.D.htm
http://avstop.com/ac/apgeneral/alternator.html (sent by jim hardy)
and there is this nice animation in http://17-11-1991.deviantart.com/art/constant-speed-drive-207261432
But I don't seem to understand how the pump part works, or what rotates in sympathy with what in that part. If you can help...
regards
I don't know how quite they work either.
But here's a thought experiment to help the mind accept that it's not too difficlut:
A positive displacement pump can be run backwards as a motor.
So by controlling flow through it you control its speed.
That let's you make a very handy device - something that absorbs or delivers torque at controllable speed.
Connect that to one axle of an automobile differential
and to the other axle, your alternator.
Now drive the input shaft with an engine at some nominal speed
and you can control alternator speed by how much flow you allow through your pump.
That's because a differential gear takes difference between two displacements.
Differential gear was a calculating element before Henry Ford latched onto it. He was a mechanical genius. We forget what an elegant function it really performs.
Now - if you run a positive displacement pump as a motor, its speed will be in proportion to flow through it.
That means it can be used to measure flow.
In 1930's a boiler fuel oil control system actually used a Model T differential to compute fuel flow. Two positive displacement pumps run as motors, one measuring supply to burners and one measuring return from burners, were geared into the axles but turned in opposite directions. Drive shaft spun at rate proportional to fuel consumed by burners and was used to set airflow to propoer air/fuel ratio..
It was before my time but my mentor remembered it well.
I think it was an old Smoot Controls system. Automatic Controls was not a so well developed field prior to WW2.
Here's an old ad:
https://www.amazon.com/dp/B005DH6KIG/?tag=pfamazon01-20
Anyhow i was reminded of this by the two "displacement units" and differential near top of this link you gave:
and this animation you linked - the swash plate probably controls flow through a positive displacement pump of some sort. Watch it move as you select speeds.
It's the exact same basic idea as thought experiment above.
Details improve but basic principles are long - lived.
Sorry for long post, but wanted to get you thinking about workings of gears and hydraulic pumps.
Hope this helps. I'll look at your links some more.
THANKS !
old jim
FAQ: Where are the alternators in jet planes?
1. How many alternators are there in a jet plane?
The number of alternators in a jet plane can vary depending on the size and type of the plane. However, most commercial jet planes have two alternators.
2. Where are the alternators located in a jet plane?
The alternators in a jet plane are typically located in the nose or tail section of the plane. They can also be found in the wings or engine compartments.
3. What is the function of alternators in a jet plane?
The alternators in a jet plane are responsible for generating electricity to power various systems and components, such as lights, navigation instruments, and communication devices.
4. How do alternators work in a jet plane?
Alternators in a jet plane work similarly to those in a car or other vehicles. They use a belt and pulley system to convert the mechanical energy from the engine into electrical energy, which is then stored in the plane's batteries.
5. What happens if the alternators in a jet plane fail?
If the alternators in a jet plane fail, the plane's batteries will eventually run out of power, causing the electrical systems to shut down. This can lead to loss of communication, navigation, and other critical functions. Pilots are trained to handle such situations and have backup systems in place to safely land the plane.
