Where between the Moon and the Earth is the gravitational potential=0 ?
In summary: When you stand on the Earth, the gravitational force pulls you down. This force is what we call weight. When you are in space, the gravitational force between the Earth and the Moon is the same. However, the gravitational force between the Earth and the astronaut is not the same. The astronaut appears to be weightless because the gravitational force is not pulling on them the way it would pull on us.
shk
78
Somewhere between the Earth and the Moon there is a point where the gravitational potential due to the Earth exactly equals that due to the Moon.
i)At what distance from the Earth is this point?
Mass of Earth = 5.98x10^24 kg
Mass of Moon= 7.35x10^22 kg
Distance between Earth and Moon = 3.84x1^8
ii) Is this the point at which the combined gravitational field is zero?Explain
b)
i) Explain why an astronaut in a spacecraft orbiting the Earth appears to be weightless?
ii)State the condition necessary for true weightlessness.
V=GM/r
g=Gm/r^2
I think
for part a ) i)
i need to equate the potential of moon and Earth to find the distance from the Earth.
for part a) ii)
I think the answer is no . because g is inversely proportional to r^2 and not r. but this pat is 3 marks so I may need to find that point by equation the g from moon and Earth. I am not really sure.
for b)i)
I think g is nearly zero in space so resultant force is zero. but this also doesn't make sense as there must be some forces as the astronaut is orbiting the Earth.
plus this is also 3 marks.
ii)I think weightlessness is when g is nearly zero
For part a) you need to do some equations.
For part b), what does "apparently" weightless mean? In physics, something is what it is measured to be. How would you measure the weight of an astronaut in orbit?
This also helps to say what "true" weightlessness is.
Likes shk
so your saying that what I have said for part a) i and ii are correct and I just need to add the equations and find those points!
for part b, i
probably this is what I need to do:
w=mv^2/r
as weight is the only force acting on the astronaut.
w=mg so by canceling the g's I'll get
g=v^2/r
but r is very big so g will be zero.
but I still don't know how to explain the apparent weightlessness and the true weightlessness
for part b, i
w=mv^2/r
g=v^2/r
##v## might be big as well!
Likes shk
shk said:
true weightlessness
True weightlessness, with no other forces present, would produce what acceleration?
you are right.
so maybe I should put it this way:
g is less than 9.8 in space but surely is not still zero so the astronaut still has weight and the weight is the centripetal force . this explains the speed.
but because the person is not pushing on anything so there won't be a reaction on him so he feels weightless. like in a lift.
and the true weightless is probably at that point between Moon and Earth where the g's cancel each other out !
zero?!
shk said:
zero?!
Right... and the acceleration of the astronaut is...?
I think the downward acceleration is g !
Little g is conventionally used for (average) gravitational acceleration at Earth's surface.
As for "downward", probably better to say "Earthward". My favourite Isaac Newton cartoon has him sitting under a tree contemplating an apple on the ground and observing "It fell down." The caption: Newton discovers tautology.
Likes SammyS, shk and gneill
I understand. I'd better say Earthward ;) thanks
But I still don't know what is the answer to this question. I need it for tomorrow. Can you please help me with this?
Thanks
Thanks
Think about how you are aware of your own weight. What force do you feel?
sorry but I need the answer to this question. Do you by any chance know the answer to help me with this. many thanks
Please try to answer post #12.
contact force/ normal reaction force
Right! So apparent weightlessness consists of feeling no applied forces, so the only applied force is gravity. Real weightlessness consists of there being no gravity.
so you're saying that apparent weightlessness is when normal reaction force is zero. like in free fall. when the only force acting on the object is it's weight . but the true weightless only happens when g=0 ?
Yes.
haruspex said:
Yes.
so the astronaut's feeling weightless because he is in free fall meaning there is no reaction force (N=0) .
and the condition of true weightlessness is when g=0.
fir the second one can i say this point can be somewhere between Moon and Earth where g's cancel each other out like we do for part a?
although i am not if it is ok to ignore the g of sun
Do you mean for b ii)?
You are only asked to state the condition. You are not asked for any specific example of where such a condition could arise, though you would not lose marks for adding that.
Isn't that L1? or am I getting my numbering order wrong on the moon's LaGrange points?
No. It is a common misunderstanding that a Lagrange point is where gravitational fields cancel.
Rather, they are points where the net field leads to the same orbital period as the larger pair of bodies.
E.g. for the Earth and Sun as the major bodies, a Lagrange point is where a much smaller body would stay at constant distances from those two.
FAQ: Where between the Moon and the Earth is the gravitational potential=0 ?
What is the gravitational potential between the Moon and the Earth?
The gravitational potential between the Moon and the Earth varies depending on the distance between the two bodies. Generally, the potential increases as the distance decreases.
Why is the gravitational potential between the Moon and the Earth important?
The gravitational potential between the Moon and the Earth is important because it determines the strength of the gravitational force between the two bodies. This force is responsible for keeping the Moon in orbit around the Earth.
What is the significance of the gravitational potential being 0 between the Moon and the Earth?
A gravitational potential of 0 between the Moon and the Earth indicates that there is no gravitational force acting between the two bodies. This occurs at a specific distance from each other, known as the Lagrange point.
How does the gravitational potential between the Moon and the Earth affect objects in space?
The gravitational potential between the Moon and the Earth affects the motion of objects in space, particularly those in orbit around the Earth. Objects closer to the Moon will experience a stronger gravitational potential, while those further away will experience a weaker potential.
Can the gravitational potential between the Moon and the Earth change?
Yes, the gravitational potential between the Moon and the Earth can change depending on the position and distance of the two bodies. As they move closer or further away from each other, the potential will increase or decrease accordingly.
