Where can i learn how Gaussian calculations various molecular properties?
In summary, Gaussian software can be used to calculate the displacement of a particular vibration because the bond length is represented on the x-axis. The software can also calculate IR vibrations if the energies of the normal modes of vibration are known. Non-harmonic vibrational energies are VERY MUCH an open topic of research in quantum chemistry.
mycotheology
89
I have a book on Gaussian but it mainly just explains how to use the program, it only gives very brief explanations of the theory behind how Gaussian does what it does. I want to gain an understanding of how Gaussian performs the various types of calculations that it can do. I understand the concept of the potential energy surface but I'm trying to figure out how it uses the potential energy surface to calculate various things about the molecule such as IR vibrations, zero point energy, thermochemical properties, UV-Vis spectra etc.
Right now I'm trying to get my head around frequency scans and how Gaussian uses the potential energy surface to calculate IR frequencies + their intensities and other things like zero-point energy and thermochemical properties etc. I've been trying to figure it out in my head because I can't find any explanations. By visualising the PES of carbon monoxide, I can see how Gaussian can use it to calculate the displacement of a particular vibration because the bond length is represented on the x-axis. I can see how it can calculate IR vibrations if the energies of the normal modes of vibration are known but I can't figure out how it could calculate the energies of the normal modes as well as the zero-point energy from the PES.
Anyone know of a book or website that explains in detail how Gaussian does what it does?
Chemistry news on Phys.org
None of these things are simple and in order to even have any idea what they're about you'd generally have to take a couple of undergrad classes and then maybe a grad class or two. Basically, calculated thermochemical properties depend on the output of Gaussian's calculations (the vibrational frequencies and moments of inertia) through equations involving "partition functions", the explanation of which is the main topic in statistical mechanics classes. As for how frequencies are calculated, they're generally done using the harmonic approximation, which works okay for deep modes near the bottom of the well (think rigid bonds in metal clusters or something) but not well at all for the low energy modes in floppy organic molecules. Finding non-harmonic vibrational energies is VERY MUCH an open topic of research in quantum chemistry. As for how you get the intensities, take a look at this paper and the references:
Ab Initio and DFT Predictions of Infrared Intensities and Raman Activities
J. Phys. Chem. A, 2011, 115 (1), pp 63–69
DOI: 10.1021/jp108057p
FAQ: Where can i learn how Gaussian calculations various molecular properties?
What is the purpose of Gaussian calculations for molecular properties?
Gaussian calculations are used to predict and study various properties of molecules, such as their energy levels, geometries, and electronic structures. This information can help scientists better understand the behavior and reactivity of molecules in different environments.
Where can I find resources to learn how to perform Gaussian calculations?
There are many online resources available for learning how to perform Gaussian calculations, such as tutorials, videos, and online courses. Additionally, many universities and research institutions offer workshops or courses on Gaussian calculations.
Are there any free software programs available for Gaussian calculations?
Yes, there are free software programs, such as Gaussian 09, which can be downloaded and used for Gaussian calculations. However, these programs may have limited features compared to paid versions.
Can Gaussian calculations be used for any type of molecule?
Yes, Gaussian calculations can be applied to a wide range of molecules, from small organic molecules to large biomolecules. However, the complexity and accuracy of the calculations may vary depending on the size and nature of the molecule.
How accurate are the results obtained from Gaussian calculations?
The accuracy of Gaussian calculations depends on various factors, such as the level of theory and basis set used, the quality of the input structure, and any simplifications made in the calculation. Generally, Gaussian calculations are considered to be highly accurate, but it is always important to validate the results with experimental data.
