Where can the water jet spray?
In summary, the conversation discusses a water jet spraying from ground level at any angle along a horizontal axis and at a velocity of $v_0$. The aim is to find an equation that describes the boundary between where the water can reach and where it cannot, ignoring drag. A hint is given to help solve the problem.
MarkFL
MHB
13,288
Consider a water jet that sprays from ground level on flat ground. The jet can spray at any angle $0<\theta<\pi$ along some horizontal axis, that is in one vertical plane. The jet sprays water at a velocity of $v_0$. Ignoring drag, find an equation that describes the boundary between where water can reach and where it cannot.
Mathematics news on Phys.org
Hi MarkFL,
I'm hoping to get some hint on how to at least start to work on the problem...:eek:
anemone said:
Hi MarkFL,
Well, since you asked so nicely...sure no problem! (Sun)
Hint:
I would begin with the parametric equations of motion:
\(\displaystyle \tag{1}x=v_0\cos(\theta)t\)
\(\displaystyle \tag{2}y=-\frac{g}{2}t^2+v_0\sin(\theta)t\)
To eliminate the parameter $t$, we solve (1) for $t$ and substitute into (2) to get:
\(\displaystyle \tag{3}y=\tan(\theta)x-\frac{g}{2v_0^2\cos^2(\theta)}x^2\)
Using \(\displaystyle \frac{1}{ \cos^2(\theta)}= \sec^2(\theta)= \tan^2(\theta)+1\) (3) becomes:
\(\displaystyle \tag{4}y=\tan(\theta)x-\frac{g}{2v_0^2}\left(\tan^2(\theta)+1 \right)x^2\)
Now, using the substitution:
\(\displaystyle u=\tan(\theta)\)
we get the parametrization:
\(\displaystyle \tag{5}y=ux-\frac{g}{2v_0^2}\left(u^2+1 \right)x^2\)
Now, let the boundary we seek be denoted by \(\displaystyle f(x)\). What can we say about the intersection of $y$ and $f(x)$?
Solution:
Continuing from the hint I gave above, we will equate $y=f(x)$ and obtain the quadratic in $u$ in standard form:
\(\displaystyle u^2-\frac{2v_0^2}{gx}u+\left(1+\frac{2v_0^2f(x)}{gx^2} \right)=0\)
Because $y$ will only ever be tangent to $f(x)$ as it is the boundary, we know therefore that the discriminant must be zero, giving us:
\(\displaystyle \left(-\frac{2v_0^2}{gx} \right)^2-4\left(1+\frac{2v_0^2f(x)}{gx^2} \right)=0\)
\(\displaystyle \left(\frac{v_0^2}{gx} \right)^2=1+\frac{2v_0^2f(x)}{gx^2}\)
And then solving for $f(x)$, we find:
\(\displaystyle f(x)=-\frac{g}{2v_0^2}x^2+\frac{v_0^2}{2g}\)
The water jet can reach a maximum height when it is sprayed at a 45 degree angle ($\theta = \pi/4$) from the horizontal axis. This is because at this angle, the horizontal velocity ($v_x$) and vertical velocity ($v_y$) are equal, resulting in the maximum range of the water jet.
Using the kinematic equations, we can find an equation that describes the boundary between where the water can reach and where it cannot. Let's assume that the water jet is sprayed from a distance of $d$ from the base point and the initial velocity of the water is $v_0$.
At any given time $t$, the horizontal position $x$ of the water jet can be described by $x = d + v_0 \cos \theta \, t$. Similarly, the vertical position $y$ can be described by $y = v_0 \sin \theta \, t - \frac{1}{2} g t^2$, where $g$ is the acceleration due to gravity.
To find the boundary where the water can reach, we need to find the time $t$ at which the water hits the ground, i.e. when $y=0$. Solving for $t$ in the second equation, we get $t = \frac{2v_0 \sin \theta}{g}$. Substituting this value of $t$ in the first equation, we get the equation for the boundary as:
$x = d + \frac{2v_0^2 \cos \theta \sin \theta}{g}$
This equation represents the maximum horizontal distance $x$ that the water can reach from the base point $d$ at any given angle $\theta$. Any point beyond this distance will be out of reach for the water jet.
In conclusion, the equation for the boundary between where the water can reach and cannot reach is $x = d + \frac{2v_0^2 \cos \theta \sin \theta}{g}$.
FAQ: Where can the water jet spray?
Where can the water jet spray be found?
The water jet spray can be found in a variety of places such as public parks, water parks, beaches, and even some residential homes.
How does the water jet spray work?
The water jet spray typically works by pumping water through a high-pressure system and then spraying it out through small nozzles. Some water jet sprays also have different settings and patterns for the water to spray out in.
What is the purpose of a water jet spray?
The main purpose of a water jet spray is for recreational use, such as cooling off on a hot day or providing entertainment at a water park. However, water jet sprays can also serve practical purposes, such as cleaning and irrigation.
How is the water in a water jet spray treated?
The water in a water jet spray is typically treated with chemicals to keep it clean and free of harmful bacteria. Some water jet sprays also have filtration systems to remove debris and impurities from the water.
Are there any safety precautions to keep in mind when using a water jet spray?
Yes, it is important to always follow safety guidelines and rules when using a water jet spray. These may include not running or playing too close to the spray, not climbing or hanging on the equipment, and always supervising children around the water jet spray.
