Where did I go wrong in simplifying this algebraic expression?
  • MHB
  • Thread starter Dustinsfl
The error was from a simple algebraic mistake in the denominator of $\beta_n$. In summary, the conversation discussed an equation involving $\alpha_n$ and $\beta_n$, which were found to be equal to certain expressions. When these expressions were plugged into the original equation, it did not match the expected solution. After rearranging the expressions for $\alpha_n$ and $\beta_n$ to have a common denominator, the error was found and the equation was able to be solved correctly.
Dustinsfl
2,281
$\alpha_nr^n + \beta_nr^{-n}$
We know that
\begin{alignat*}{3}
\alpha_na^n+\beta_na^{-n} & = & A_n\\
\alpha_nb^n+\beta_nb^{-n} & = & 0
\end{alignat*}
So I ended up with
\alpha_n = \frac{-A_n}{b^{2n}/a^n-a^n}
and
\beta_n = \frac{A_n}{1/a^n-a^n/b^{2n}}
When I plug them in, I obtain
\left(\frac{a}{r}\right)^nA_n\frac{b^{2n}/a^n-r^{2n}}{b^{2n}-a^{2n}}
However, the solution is supposed to be
\left(\frac{a}{r}\right)^nA_n\frac{b^{2n}-r^{2n}}{b^{2n}-a^{2n}}
I cannot find my error.
Mathematics news on Phys.org
We know that
\begin{alignat*}{3}
\end{alignat*}
So I ended up with
and
I think by rearranging the answers for \(\alpha_n\) and \(\beta_n\) to have a common denominator may help in the algebraic simplification.
\[\alpha_n=\frac{-A_{n}a^n}{b^{2n}-a^{2n}}\]
\[\beta_n=\frac{A_{n}a^nb^{2n}}{b^{2n}-a^{2n}}\]
\begin{eqnarray}
\therefore \alpha_nr^n + \beta_nr^{-n}&=&\left(\frac{-A_{n}a^n}{b^{2n}-a^{2n}}\right)r^n+\left(\frac{A_{n}a^nb^{2n}}{b^{2n}-a^{2n}}\right)r^{-n}\\
&=&\frac{A_{n}a^nb^{2n}-A_{n}a^nr^{2n}}{r^n(b^{2n}-a^{2n})}\\
&=&\left(\frac{a}{r}\right)^nA_n\frac{b^{2n}-r^{2n}}{b^{2n}-a^{2n}}
\end{eqnarray}
\begin{eqnarray}
\end{eqnarray}
I marked the thread solved a little bit ago.
FAQ: Where did I go wrong in simplifying this algebraic expression?
What is algebraic simplification?
Algebraic simplification is the process of reducing a mathematical expression into its simplest form by combining like terms and using various algebraic rules and properties.
Why is algebraic simplification important?
Algebraic simplification is important because it allows us to solve complex equations and problems more easily and efficiently. It also helps us to understand the underlying structure and relationships within an expression.
What are the basic rules of algebraic simplification?
The basic rules of algebraic simplification include the commutative, associative, and distributive properties, as well as rules for combining like terms, removing parentheses, and simplifying fractions.
How do you simplify expressions with exponents?
To simplify expressions with exponents, we use the rules of exponents, such as the power rule, product rule, and quotient rule. We also look for opportunities to apply the properties of exponents, such as combining like bases or using negative exponents.
Can all algebraic expressions be simplified?
No, not all algebraic expressions can be simplified. Some expressions may already be in their simplest form, while others may not have any common factors or terms to combine. In some cases, simplifying an expression may result in an equivalent but longer expression.
