Where did the water balloon fall?
A boy throws a water balloon horizontally from a 12 m tall building, releasing it at a height of 1 m above the roof. The balloon is aimed at an apartment building 18 m away and initially calculated to travel at 30 mi/h, which was incorrectly converted to 80.3 m/s. After correcting the conversion to 13.4 m/s, the time of flight was recalculated to 1.34 seconds, leading to a vertical drop of 8.8 m. This drop indicates that the balloon would hit the third floor of the apartment building. The discussion emphasizes the importance of accurate unit conversions and careful calculations in physics problems.
Medgirl314
A boy is on top of a 12 m tall building. He throws a water balloon horizontally, releasing it at a height of 1 m above the top of the building. The water balloon is thrown at 30 mi/h and is aimed at the balconies of an apartment building across the street, 18 m away horizontally. If each story of the apartment building is 3 m high, which balcony gets hit by the water balloon, 1st, 2nd,3rd or 4th floor?
t=x/v
y=y0+v0t1/2 a(t^2)
I attempted to convert the mi/h to m/s and got 80.3 m/s. I used t=x/v to get my time:
t=x/v
t=18/80.3
t=0.22 s
The time seems reasonable enough.
Then I tried using y=y0+v0t+1/2 a(t^2) to find how far down the balloon fell.
y=y0+v0t+1/2a(t^2)
1/2 a(t^2)
y=0+0+1/2 a(t^2)
y=1/2a(t^2)
y=1/2(9.8)(0.22^2)
y=1/2(9.8)(0.0484)
y=0.24 m
Something seems off, but I can't place it. If this answer is right, does that mean it will land on the 4th(top) floor of the building?
Thanks! :smile:
Try your conversion of 30 mi/hr to m/s again. 80.3 m/s is a very fast clip.
Hm, I thought so. 30 mi=48280.3 m. OH, I see. I calculated to m/min. I need to divide by 60 again, correct? So 1.3 m/s.
1.3 m/s is a casual strolling speed. You need to set up your calculations in an organized fashion and not try to 'shoot from the hip'. It's not clear where 80.3 m/s came from originally.
I didn't think about it that way. Hmm. Okay, so 30 mi/h=48280.3 m/h. Line up the unit conversion so that the hours cancel out. 48280/3600 s=13 m/s. That seems right, finally.
Is the time right?
I'm getting 9.3 meters, which would put it at the second (next to bottom) floor. Feel free to confirm or correct the answer! :)
13.4 m/s hits in 1.34s after dropping 8.8m (from 13m start).
avoid round-offs (especially for things that get squared, like t here), by using the value in the calculator display register.
Ah, I see. I used 1.38 seconds. Now I'm getting 8.8 as well. So this should put the balloon at the third (from bottom) floor, correct?
Thanks again!
This post is only here because I couldn't delete it.
huh? 13m - 8.8m = ? 1st floor 0 to 3m, 2nd floor 3m to 6m, 3rd floor 6m to 9m, 4th floor 9m to 12m ... right?
4.2 m. Correct, I don't think I'm thinking about the diagram correctly. It would actually be the second floor, right?
  • · Replies 32 ·
  • · Replies 38 ·
  • · Replies 62 ·
