Where do electromagnetic waves get their energy from?
In summary, electromagnetic waves (EMW) are generated by accelerating charges, such as in a dipole antenna. When a charge is accelerated, it gains kinetic energy and also radiates EMW, which carries energy itself. This means that it takes more energy to accelerate a charged object than an identical object without charge. The energy that is not radiated is stored in the reactances, and when the antenna is fed at its natural resonant frequency, it can be made to radiate. The actual kinetic energy involved in the average movement of electrons is very small compared to the energy associated with the oscillating magnetic and electric fields. Therefore, the energy that is not radiated is converted into potential energy and does not contribute to the radiation of
radio171
We know that EMW are generated by accelerating charges.
If I accelerate a charge it should gain kinetic energy equal to half the mass of the charge times velocity squared.
But at the same time it will radiate electromagnetic waves which carry energy itself.
So where does this energy come from?
It seems that it requires more energy to accelerate the charge and some of this energy is radiated.
If so, how do I know how much of it is turned into EMR and how much is turned into kinetic energy.
Please, correct me, because my logic doesn't make sense.
You are correct. It takes more energy to accelerate a charged object than it would take to accelerate an otherwise identical object.
There are many ways in which an EM wave can be generated but consider a simple transmitter feeding a dipole. During each cycle, charges (electrons) are accelerated in either direction and most of the energy is stored in the local fields (as each side of the dipole is charged and discharged). This involves both KE and PE. But, as well as the energy per cycle that is sloshing about in the dipole, there is EM energy radiated in the form of a wave and this actually appears (to the transmitter) as a resistance. The energy that's not radiated builds up in the reactances. When the dipole is fed at it's natural resonant frequency, it is easiest to match to the transmitter / feeder but an antenna of any shape or length can be made to radiate.
It's worth remembering that the actual KE involved in the average movement of electrons in time with the EM wave frequency is actually very tiny and the energy associated with the currents (movement of charge) is actually the form of an oscillating magnetic field. As an exercise, calculate the maximum velocity and displacement of an electron with a mean drift speed of a couple of mm per second (at DC) when the field is being alternated at 10MHz and a field of, say 10V/m.
The displacement of charge is associated with the oscillating electric field.
It seems to me that your worry about where the KE goes can be resolved by considering the Potential Energy that it's converted to. It's only the in-phase components of these fields that actually radiates as a wave. Locally, there is a complicated jumble of oscillating fields in a variety of phases and directions and these don't radiate.
Related to Where do electromagnetic waves get their energy from?
1. Where does the energy in electromagnetic waves come from?
The energy in electromagnetic waves comes from the movement of electrically charged particles. These particles, such as electrons, are constantly in motion and create an electric field. When they accelerate or change direction, they create a magnetic field. The interaction between these electric and magnetic fields generates electromagnetic waves, which carry energy with them as they travel through space.
2. What is the source of energy for electromagnetic waves?
The source of energy for electromagnetic waves can vary depending on the specific situation. In some cases, it may be a power source, such as a battery or generator, that is used to create and transmit the waves. In other cases, the energy may come from natural sources, such as the Sun or other stars, which emit electromagnetic waves as a result of nuclear reactions.
3. How do electromagnetic waves transfer energy?
Electromagnetic waves transfer energy through a process called radiation. As the waves travel through space, they create a constantly changing electric field, which then creates a constantly changing magnetic field. This back-and-forth motion of the electric and magnetic fields results in the transfer of energy. This energy can then be absorbed by objects in the path of the waves, such as antennas or solar panels.
4. Can electromagnetic waves lose energy?
Yes, electromagnetic waves can lose energy as they travel through space. This is known as attenuation and can occur due to a variety of factors, such as absorption by objects in their path, scattering due to interactions with particles in the atmosphere, or simply spreading out over a larger area as they travel further from their source. However, electromagnetic waves can also be amplified or regain energy through interactions with other sources, such as amplifiers or reflections.
5. How does the energy of electromagnetic waves compare to other types of energy?
The energy of electromagnetic waves is a type of kinetic energy, as it is associated with the movement of particles. It is also a form of radiant energy, as it is transmitted through space in the form of waves. Compared to other types of energy, such as thermal or mechanical energy, electromagnetic energy is unique in that it does not require a medium to travel through and can travel at the speed of light. Additionally, electromagnetic waves can have a wide range of energies, from low-energy radio waves to high-energy gamma rays.
  • Electromagnetism
  • Electromagnetism
