Undergrad Where do these time derivatives of Pauli matrices come from?
The discussion centers on the time derivatives of Pauli matrices, which describe the motion of spin in a magnetic field, and their relationship to classical mechanics through Poisson's brackets. The equations of motion derived from the Pauli matrices indicate that the x and y components of spin precess around the z-axis, while the z component remains unchanged. The conversation also touches on the Heisenberg picture of quantum mechanics, emphasizing the role of the magnetic moment and its interaction with a magnetic field. Additionally, there is curiosity about the relationship between Hamiltonians, Lie brackets, and their implications in quantum theory. The discussion highlights the importance of Lie groups and algebras in understanding quantum mechanics and angular momentum.
docnet
TL;DR
Where do these time derivatives of Pauli matrices come from? These are in Susskind's Theoretical Minimum (which is not the best text to learn quantum mechanics from, I have heard). He introduces these equations as "the equations of motion" of the spin in a magnetic field. $$ \frac{d}{dt}\sigma_x=-i[\sigma_x,\sigma_z]\frac{\omega}{2}$$$$
\frac{d}{dt}\sigma_y=-i[\sigma_y,\sigma_z]\frac{\omega}{2}$$$$ \frac{d}{dt}\sigma_z=-i[\sigma_z,\sigma_z]\frac{\omega}{2}$$
Wolfgang Pauli's matrices are
$$\sigma_x=\begin{bmatrix}0& 1\\1 & 0\end{bmatrix},\quad \sigma_y=\begin{bmatrix}0& -i\\i & 0\end{bmatrix},\quad \sigma_z=\begin{bmatrix}1& 0\\0 & -1\end{bmatrix}$$
\frac{d}{dt}\sigma_x=-\omega\sigma_y,\quad
\frac{d}{dt}\sigma_y=\omega\sigma_x,\quad
\frac{d}{dt}\sigma_z=0$$
"These are analogous to Saméon Poisson's brackets of angular momentum describing the rotational motion of a rigid body in classical physics. The ##x## and ##y## components of the spin precess around the ##z## axis, while the ##z## component of the spin does not change".
I am interested in how Susskind got the right hand side of the three equations.
They are not derivatives of the path in ##\operatorname{SU(2)}## ##\gamma: q\longrightarrow I_2## given by the rule $$\gamma(t)=q(t)=U\begin{pmatrix}e^{i\theta_1 t}&0\\0&e^{i\theta_2 t} \end{pmatrix}U^{-1}$$ with ##\gamma(0)=I_2## and ##\gamma(1)=q##.
I suspect those are operator equations which apply to the specific states in this particular scenario. I.e. if ##|\alpha(t) \rangle## is the state of the system at time ##t##, then:
$$(\frac d {dt})(\sigma_x)|\alpha(t) \rangle = -i \frac \omega 2 [\sigma_x, \sigma_z] |\alpha(t) \rangle = -\omega \sigma_y |\alpha(t) \rangle$$
PS which, I guess, is another way of saying he's using the Heisenberg picture.
One should note that the spin of a charged particle (or a neutral particle being bound states of charged particles like the neutron) imply a magnetic moment,
$$\vec{\mu}=\frac{q}{2m} g \vec{s}.$$
Here ##q## is the charge, ##m## the mass the particle, and ##g## the socalled gyro-factor or Lande-factor. For an electron it's close to 2.
The potential for the forces on a dipole is
$$V(\vec{x},\vec{s})=-\vec{\mu} \cdot \vec{B}=-\frac{q g}{2m} \vec{s} \cdot \vec{B}.$$
For the equation of motion of the spin (in the Heisenberg picture of time evolution) you get
$$\dot{s}_a=\frac{1}{\mathrm{i} \hbar} [s_a,H]=-\frac{q g}{2m \mathrm{i} \hbar} B_b \cdot [ \sigma_a,\sigma_b] =-\frac{q g}{2 m \hbar} B_b \epsilon_{abc} s_c = -\frac{q g}{2m \hbar} \epsilon_{abc} B_b s_c= -\frac{q g}{2m \hbar} (\vec{B}\times \vec{s})_a$$
or
$$\dot{s}_a=\frac{q g}{2 m \hbar} \vec{s} \times \vec{B}=\vec{\mu} \times \vec{B},$$
as expected also from classical electromagnetism.
Note that for spin-1/2 particles ##\vec{s}=\hbar \vec{\sigma}/2##.
Likes dextercioby and docnet
Okay. Question: Do the Hamiltonians with the Lie bracket operation form groups that are used in physics? (seriously, really curious.) Another question: Does this imply the the cross product in ##\mathbb{R}^3## corresponds to the Lie bracket of vector fields?
A lot of quantum theory is indeed best understood using the ideas of Lie groups and Lie algebras. E.g., the commutation relations between position and momentum result from the meaning of momentum as generators of spatial translations. In QT the Lie bracket is realized with self-adjoint operators describing observables via ##\frac{1}{\mathrm{i}} [\hat{A},\hat{B}]##. The additional factor ##1/\mathrm{i}## ensures that the Lie bracket maps to another self-adjoint operator.
The commutation relations of angular momenta result from the fact that they are the generators of rotations, which in QT are represented by representations of the covering group SU(2) of the rotation group. Thus you have
$$[\hat{J}_a,\hat{J}_b]=\mathrm{i} \hbar \epsilon_{abc} \hat{J}_c.$$
That's valid also for orbital angular momentum and spin separately, because in non-relativistic physics the spin operators commute with orbital angular momentum.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 22 ·
  • · Replies 17 ·
