Where do virtual particles come from?
In summary, the video said that black holes evaporate via Hawking radiation. If I understood the video correctly, a virtual particle can pop into existence just outside the event horizon, and that one of the resulting pair can subsequently fall back into the black hole while the other one escapes, thus causing the black hole to lose mass. But how do we know that the virtual particles that pop into existence around a black hole actually came from inside the black hole? Couldn't they have come from anywhere? After all, if virtual particles are constantly popping into existence even in a vacuum, how do we know where those virtual particles are coming from? And if the pair didn't come from inside the black hole, then aren't they just as likely to
Fiziqs
134
TL;DR Summary
How do we know that the virtual particles involved in Hawking radiation actually came from inside the black hole?
I watched a Youtube! video on black holes, and it said that black holes evaporate via Hawking radiation. If I understood the video correctly a virtual particle can pop into existence just outside the event horizon, and that one of the resulting pair can subsequently fall back into the black hole while the other one escapes, thus causing the black hole to lose mass.
But how do we know that the virtual particles that pop into existence around a black hole actually came from inside the black hole? Couldn't they have come from anywhere? After all, if virtual particles are constantly popping into existence even in a vacuum, how do we know where those virtual particles are coming from? And if the pair didn't come from inside the black hole, then aren't they just as likely to be adding mass to the black hole rather than taking it away?
Thanks
We don't, because, first, Hawking radiation isn't made of virtual particles, and second, Hawking radiation doesn't come from inside the black hole.
Likes bhobba, Demystifier, QuantumQuest and 1 other person
You should not be trying to learn science from pop science Youtube videos. You are much more likely than not to get misleading information, as it appears you have in this case.
Likes bhobba and mattt
Actually, the "particles" (quantum fields) constituting hawking radiation are not localized when they leave the black hole.
But when they leave the black hole in very large numbers they should be fairly well localized(on average).
From the imaginations of those doing the calculations.
Likes bhobba, mattt, QuantumQuest and 2 others
Related to Where do virtual particles come from?
1. What are virtual particles?
Virtual particles are subatomic particles that are predicted by quantum field theory to exist for a very short period of time. They are not considered to be actual particles, but rather fluctuations in the quantum field.
2. Where do virtual particles come from?
Virtual particles are thought to arise from the inherent uncertainty in the quantum field. They can also be created in high-energy collisions, such as those that occur in particle accelerators.
3. Do virtual particles have mass?
Yes, virtual particles are believed to have mass, but it is not the same as the mass of actual particles. Their mass is determined by the energy and momentum of the quantum field.
4. How do virtual particles differ from real particles?
Virtual particles are different from real particles in several ways. They have a shorter lifespan, do not follow the laws of conservation of energy and momentum, and cannot be directly observed or detected.
5. Can virtual particles become real particles?
Yes, virtual particles can become real particles under certain conditions. For example, in a vacuum, virtual particles can interact and produce real particles. This is known as pair production.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
13K
  • Quantum Physics
