Where does the 1/2 in 1/2 at^2 come from?
In summary, the 1/2 in the equation 1/2 at² arises from the derivation of the formula for the distance traveled by an object undergoing constant acceleration from rest. It represents the average velocity of the object during the time interval, as it starts from zero and accelerates uniformly to a final velocity. The factor of 1/2 accounts for this averaging process, leading to the expression for displacement in terms of acceleration and time.
Astro-Eddie
TL;DR Summary
Why is distance=1/2 at^2? Can you explain without using calculus? (I'm not in B. I'm lower)
I am currently studying Newton's laws and mechanics. I have this question: Why is distance=half a*t^2? Where did the 1/2 come from? Can someone explain this without using calculus?
Astro-Eddie said:
TL;DR Summary: Why is distance=1/2 at^2? Can you explain without using calculus? (I'm not in B. I'm lower)
No, sorry. The equation comes directly from the calculus involving integration and differentiation. How long until you take your first calculus class?
https://en.wikipedia.org/wiki/Equations_of_motion
  • Skeptical
Likes topsquark and strangerep
A very simple explanation would be if you start from velocity = 0 and apply a constant acceleration, then if you plot velocity versus time it would form a triangular shape between the plot and the time axis.
The area under the curve is equal to the distance covered. What's the area of that triangle?
Likes PeroK, vanhees71, russ_watters and 9 others
Consider a constant acceleration from zero.
The area of the acceleration graph with time is velocity; v = a * t ;
The velocity graph is therefore a triangle against time.
The area of a triangle is = ½⋅height⋅base
The area under the velocity graph against time is displacement; s.
s = ½⋅v⋅t = ½⋅a⋅t² .
Likes ebg, vanhees71 and Lnewqban
(must.resist.urge.to.remind.that.areas.are.coming.from.integrations...) :wink:
  • Haha
Likes pinball1970, vanhees71, russ_watters and 2 others
Say that we have an object that starts at time ##t_0 = 0## s, at a point ##x_0##, with an initial velocity ##v_0## and moves with a constant acceleration ##a##, and travels for a time ##t##. (All in 1D.)
We know that
##v = v_0 + at##
and
##\overline{v} = \dfrac{x - x_0}{t}## ##\leftarrow## average velocity
Now, the average velocity can also be found as
##\overline{v} = \dfrac{v_0 + v}{2}##
(for motion with constant acceleration.)
So let's put some of this together:
##\dfrac{x - x_0}{t} = \dfrac{v_0 + v}{2}##
or
##x = x_0 + \dfrac{v_0 t}{2} + \dfrac{v t}{2}##
and using ##v = v_0 + at##
##x = x_0 + \dfrac{v_0 t}{2} + \dfrac{(v_0 + at) t}{2}##
##x = x_0 + \dfrac{v_0 t}{2} + \dfrac{v_0 t}{2} + \dfrac{1}{2} a t^2##
##x = x_0 + v_0 t + \dfrac{1}{2} a t^2##
-Dan
Likes hutchphd, Frabjous, erobz and 2 others
Easiest explanation:
We start at speed zero, we accelerate for time ##t## so our speed is ##at##.
Our average speed therefore is the average of ##0## and ##at##, which is ##\frac{1}{2}at##.
(This only works for constant acceleration, but that's we're doing here)
Distance traveled is speed times time, so If we move at an average speed of ##\frac{1}{2}at## for time ##t## the distance is ##\frac{1}{2}at^2##.
Take a moment to draw a rectangle of height ##\frac{1}{2}at## and width ##t##, compare with the triangle that @gneill drew in post #3 above.
Likes hutchphd and topsquark
We know that
##v = v_0 + at##
and
or
-Dan
is the v in the very first equation the final velocity? Also, why d we divide Vo+V by 2 for the average velocity?
Yes, v is the final velocity.
As to the average, for example, how do you find the average of the set
(v,t) = {(2.0,0), (2.5,1), (3.0,2), (3.5,3), (4.0,4)}?
That would be the middle point of the set, so
##\left ( \dfrac{2.0 + 4.0}{2}, \dfrac{0 + 4}{2} \right ) = (3.0, 2)## (in whatever units.)
But this means that the average v is just the sum of the two endpoints divided by 2.
-Dan
Likes binis and Astro-Eddie
The fact that you avoid the word "calculus" does not mean that you are not using it. You are using results from calculus when you say that the average velocity for constant acceleration is the average of the velocities at the end of the interval. It is not a self evident truth. The same for using the geometrical method. Arhimedes used it and even though he did not call it calculus, it was.
So it is true what @berkeman said, you are still using calculus to justify the factor of 1/2.
I am not saying that it is not useful to show some sort of justification for students in non-calculus physics classes. You can easily justify the fact that the distance is not ##at^2## but a smaller fraction of this, due to the fact that the velocity was smaller than the final velocity during the motion. But the fact that the fraction is 1/2 and not 1/3 or any other requires the methods that we call "calculus". Whatever method you use to "justify" it, I think it is fair to tell the students that the result can be proven by mathematical methods they will learn later in calculus.
Whereas it is true that you can easily prove the average velocity formula using mean value integration formula, that does not mean you can't do it without Calculus. The simple example I used above proves it without invoking any Calculus.
I don't mean to say that using Calculus for Introductory Physics isn't easier, nor am I saying that none of Introductory Physics relies on it. Far from it. But projectile motion under constant acceleration, in particular, does not require Calculus in order to derive most of its results. The position formula is one such that does not require Calculus. To say that you can't understand the formulas without Calculus simply isn't true and IMHO just makes the field needlessly obscure to a new learner who does not yet know it.
Time enough to learn these concepts when they become necessary, and you really do not need Calculus for Physics I unless you are going to continue onto Physics II (where I agree that Calculus is absolutely necessary.)
-Dan
You did not prove that the average velocity (defined as total displacement over total time) is equal to the arithmetic mean of the velocities at the ends of the interval. Why should be the value in the middle of the set be equal to the average velocity defined in the usual way for motion? What is the distance travelled associated with this set of (v,t) values?
Learn calculus before going any further. The long derivation without calculus shows you why
  • Skeptical
Likes PeroK
We don't need calculus to calculate the area of a rectangle or triangle. The fact that it can also be done using calculus, doesn't mean calculus is necessary.
The displacement is the area under a velocity time graph. Which, for constant acceleration, is a combination of rectangles and triangles. No calculus is needed to calculate the average velocity in this case.
Likes russ_watters and topsquark
For constant acceleration, the average velocity is midway between the starting and ending velocity. The distance traveled is the average velocity times elapsed time.
The irony is that to develop the integral calculus the area of rectangles and triangles is normally used. So, an appeal to calculus to prove that the area of a triangle is 1/2 x base x height is a circular argument.
PeroK said:
We don't need calculus to calculate the area of a rectangle or triangle. The displacement is the area under a velocity time graph.
It's not calculating the area but the fact that the distance travelled is equal to the area. I consider this as part of calculus. The area under the curve of the graph of a function is the integral of the function. Does not matter how you calculate that integral, by measuring the area or by analytics methods.
  • Skeptical
Likes PeroK and vanhees71
The analytics method is called calculus. Geometry predates calculus by a couple of millennia. You do not need calculus to do geometry, or work out the area of a geometric figure.
Prior to calculus, you could have solved the problem with geometry.
Likes russ_watters, PeroK and topsquark
What more proof do you need? Let's take this down a step. Say we're talking about motion with constant velocity. What is the average displacement for a data set for motion with a constant velocity? Is this not
##\overline{x} = \dfrac{x_0 + x}{2}##
It's simply finding the "center" of a geometric construction. Yes, if acceleration weren't constant we couldn't do this and the non-Calculus derivation of
##x = x_0 + v_0 t + \dfrac{1}{2} a_0 t^2 + \dfrac{1}{6} j t^3##
(motion with a constant jerk) would be... annoying. And, certainly, if nothing about the motion was constant you would definitely need to use Calculus. All I'm saying is that, for the specific case of constant acceleration, we don't need Calculus.
-Dan
The very fact that the velocity is given by the area under the curve ##(t,a(t))## is an application of the fundamental theorem of calculus. You may argue without explicitly writing integrals, but you'll have to argue with arguments leading to the definition of the integral (most "naturally" using the Riemann integral in this case). I never understood, what's the merit of this "calculus-free approach" to physics. You don't need the full formalism of 19th-century analysis to get pretty far in physics, but introducing the notion of derivatives and integrals at least on this heuristic level, makes things way more clear than avoiding them.
Likes DaveE
The proof of which rests on the known area of rectangular and triangular shapes. These simple geometric calculations predate calculus, as mentioned above.
Likes topsquark and russ_watters
The fact to derive that it IS this area is already calculus.
I'd start with the definition of "momentary velocity" in the usual way to calculate finite differences ##\Delta \vec{x}/\Delta t## and take the limit ##\Delta t \rightarrow 0##. That's of course the derivative, and one should be allowed to call it such and also to derive the basic rules how to calculate with it (taking derivatives of the elementary functions, product/quotient rule etc.).
Analogously you get the acceleration as the time derivative of velocity.
Then that the opposite operation is integration and leads to the "curve under" the velocity-component-time diagram to get the corresponding position-vector component can also be motivated in a pretty intuitive geometric way (analogously the velocity from a given acceleration ##a(t)##).
All that's needed from "elementary measure theory" is indeed that the area of a rectangle is length times width.
Likes nasu
Which problem would you have solved with geometry? How do you know what area to calculate to get the distance travelled in a non-uniform motion? What geometry theorem tells you this?
Yes, this is what I mean. The problem is not not how to calculate the area.
Likes vanhees71
The very notion of an intantaneous velocity and acceleration is at the heart of differential calculus ) so the OP is self-referential, leading us directly to wallow in the semantic swamp. Surf's up...
Likes DaveE, Vanadium 50, berkeman and 2 others
I'm building a working office in my house right now. I had to determine the area of a rectangle to buy the floor. My construction worker told me to apply calculus.
  • Haha
Likes vanhees71, topsquark and PeroK
My mother needed tiles for her garden. She wants a nice triangle and asked me how many tiles she should buy. I told her to use calculus.
Likes vanhees71 and topsquark
What's the area of a football field you ask? Worry not. Use calculus.
What I try to say is you shouldn't add apples and oranges. Even though that's calculus.
  • Haha
  • Skeptical
Likes vanhees71 and DaveE
Does she still love you?
Good thing she didn't ask you to optimize something... :wink:
  • Haha
Likes vanhees71, nasu and topsquark
  • #31
Folks, I'll start this by saying I'm on a new medication and that I'm a little b!tchy. But please consider the following:
1. The OP requested a non-Calculus proof for the formula. This implies that they either have not taken Calculus or that they are in a non-Calculus course.
2. Mentioning that Calculus makes Physics easier is fine. Saying that it is a requirement in order to solve this problem is simply not true.
3. Telling the OP that you need Calculus to understand where the equation comes from is wrong, irrelevant to the OPs needs, and somewhat elitist. I totally agree that Calculus is an essential tool for understanding Physics. But it is not what everyone needs.
Please consider that this whole conversation about whether Calculus is necessary to understand Physics, or that Calculus makes it easier, is completely outside of the question posed by the OP. There is already another thread in progress about "how can you teach Physics without Calculus." I recommend that you put your arguments there, where it is more to the point, rather than here, where it is simply not relevant.
-Dan
Likes Tom.G, Motore, PeroK and 4 others
  • #32
If the OP needs an explanation without using some tool, the need is supposed to make it happen even if there isn't one?
He can get a justification, an intuition for why may be so, for why is reasonable to accept it for now as it is. Is done all the time in high school physics and algebra based university courses. What is the harm in telling him that this is not a proof without calculus, just a proof that uses an easier to understand method or result of calculus.
Like, area under the graph of force versus distance is equal to the work of the force or area under the graph of velocity versus time is the distance travelled. By using this he can see why for uniform acceleration the average velocity is equal to the arithmetic mean of velocity and why isn't in general so. Or why the work of the elastic force is the way it is.
But this not "without calculus", just without the word "calculus". Kind of politically correct physics in algebra based courses where the students get offended if they hear "calculus".
  • Sad
Likes PeroK and berkeman
  • #33
But the derivation does not require Calculus! The OP didn't want a Calculus based explanation, and it did not need one. My reply essentially comes from my High School Physics class, which was not an AP course (my High School didn't offer AP.) It is correct in all the details, and doesn't require any Calculus to understand it.
Yes, the proof is 4 lines shorter if you use Calculus. So what? The question is not about teaching the OP about areas under the curve nor is it about nor why the arithmetic mean of the velocity is not the same as the average velocity in the general case. When I presented my proof I did mention that the arithmetic mean equation only worked for constant acceleration. But by insisting on mentioning Calculus you are moving directly away from what the OP was asking: How to show where the 1/2 comes from without using Calculus. You aren't answering the question: you are expanding on it. That is simply not necessary in this case and it can only serve to put off the OP.
Yes, some people are threatened by Calculus. I don't really know why. Personally, I found my Calculus classes to be relatively easy. (So easy that I effectively taught myself most of Calculus I - III while I was in my Senior year of High School, mistakenly thinking that the whole text was just Calculus I.) But the fact remains that some people are. So why pressure the point? If the student is not bound to be a Physics, or related, major why worry about if they are not told a Calculus based proof when a non-Calculus based proof was readily available?
Just to be clear: whereas I am saying that it is possible to show where the 1/2 comes from without Calculus, I am generally not against your comments as to how Calculus is needed in learning Physics properly. It's just that it doesn't sound like the OP needs to learn those lessons, thus I do not believe that they belong in this thread: the Calculus comments are a tangent and do nothing to help the OP.
-Dan
Likes Motore
  • #34
If the OP thinks that his statement of the problem does not already use calculus he needs to be educated. I presume this need is why he has self-identified as a student. The very notion of an instantaneous velocity is the crux: an educator needs to be certain that knowledge is part of his Physics education despite the demand of "no calculus". The only question is how advanced.
I wish to learn English Literature but no Shakespeare.......
American History but no slavery please. I am weary.
  • #35
I think we're getting tangled up in knots here.
Let's review - the OP asked where the 1/2 came from, and was told that the distance traveled is the average speed times the time. The average is half the sum of the initial and final velocities.
This is a fine, non-calculus based answer. Unfortunately, the OP rejected it.
Now we're trying to defend it by coming up with some sort of hand-wavy crypto-calculus. Given that we will never get to the bottom of the "but why?" ladder, nor can we guess what answer the OP finds acceptable, maybe we should have stopped there.
Likes pbuk and nasu
