entropy1
- 1,230
- 71
If a static magnet attracts an object A, where does the kinetic energy that A acquires come from?
DrClaude said:It comes from the potential energy that was previously there. The original state, before the object started moving, had a higher potential energy, so you can try to trace where that energy came from.
I don't understand, so let me ask a second question: the potential is brought with the magnet, right? Without magnet de potential energy wouldn't be there. So where does the magnet get its potential to produce potential energy in A from?DrClaude said:It comes from the potential energy that was previously there. The original state, before the object started moving, had a higher potential energy, so you can try to trace where that energy came from.
entropy1 said:I don't understand, so let me ask a second question: the potential is brought with the magnet, right? Without magnet de potential energy wouldn't be there. So where does the magnet get its potential to produce potential energy in A from?
I can image that, if A was stuck to the magnet in the first place, the potential energy would increase by retracting it from the magnet. So then is the sticking to the magnet somehow the natural state of A?
It's the minimal energy state.entropy1 said:So then is the sticking to the magnet somehow the natural state of A?
stockzahn said:If you have a ferromagnetic material like iron in a magnetic field and you treat it and add certain components to produce an austhenitic steel (which is not ferromagnetic). What happens to the potential energy then?
entropy1 said:So where does the magnet get its potential to produce potential energy in A from?
Vanadium 50 said:You are describing a phase transition, just like melting ice or boiling water. There's energy accompanying a phase transition.
Is it correct to say that objects that are attracted by a magnet already have this potential? For instance: if we craft a magnet, from then on it gives all metal in the universe some more potential. If that is so, wouldn't crafting the magnet require enough energy to account for that acquired potential?Vanadium 50 said:Same place a spring does.
Yes.entropy1 said:Is it correct to say that objects that are attracted by a magnet already have this potential? For instance: if we craft a magnet, from then on it gives all metal in the universe some more potential.
No, the magnet does not have potential energy, the system does (magnet + whatever it is attracted to). Also, "potential" is not "potential energy". So having "potential" does not require generation of "energy".If that is so, wouldn't crafting the magnet require enough energy to account for that acquired potential?
The energy in a magnet comes from the alignment of its microscopic magnetic domains. These domains contain electrons with a specific spin, which creates a magnetic field. When these domains are aligned, they create a stronger magnetic field and therefore more energy.
Energy is produced in a magnet through the movement of electrons. When a magnet is placed near a conductive material, such as a wire, the magnetic field will cause the electrons in the wire to move, creating an electrical current. This movement of electrons is what produces energy.
No, a magnet cannot run out of energy. The energy in a magnet is a result of the alignment of its microscopic magnetic domains, which are a fundamental property of the material. As long as the material remains intact, the magnet will retain its energy.
The source of energy in a permanent magnet is the alignment of its magnetic domains, which is a result of the material's atomic structure. This alignment creates a magnetic field, which is the source of the magnet's energy.
A magnet creates energy through the movement of electrons. When a magnet is moved near a conductor, such as a wire, the magnetic field will cause the electrons in the wire to move, creating an electrical current. This current can then be used to power devices or perform work.
