Where does the energy in LED come from?
In summary, the conversation discusses the energy levels and movement of electrons and holes in N-type and P-type materials, and how light is emitted when they recombine. The energy for this process comes from the power supply and nature's desire for lower potential energy. The LED light is created at the N-P junction and its energy is equal to the energy gap of the semiconductor. The 0.7 V drop is due to the depletion region and the ohmic contact with the leads. Metals cannot produce light because of their different electronic structure.
jaydnul
558
I know that the electrons in the N-type are in the conduction energy level, while the holes in the P-type are in the valence energy level, so when they recombine light is emitted.
What I don't understand is where that energy comes from. The electrons in a copper wire can freely flow from the valence to conduction level (and vice versa) anytime, right? So how is it that the electrons can just enter into the N-type at the conduction band and exit the P-type at the valence band? The .7V drop is to do with the depletion region, right? It has nothing to do with the light that's emitted?
Thanks
it comes from the power supply
Yes, there is a very brief spontaneous movement of charge. Where the p-type and n-type material meet some of the free electrons on the n-type side will jump across and combine with the hole on the p-type side. They do this because full electron shells have lower potential energy (same reason why chemical bonding happens)[EDIT: I mean full octet]. But the charges in the nuclei stay behind. The result is that an electric field develops that opposes further spontaneous movement of charge. Why can't you hook up a wire and drain the charge imbalance back to where it belongs so that the current can go round and round? Because that would require applying some energy to pull the electrons back out of the valence holes. Most of physics comes down to nature's desire for lower potential energy ("entropy tends to increase") and the ultimate conservation of energy (and momentum, and a few other things).
Search YouTube for how diodes (light emitting or otherwise) work.
Yes, you are correct. Semiconductors are material that have (at zero absolute temperature) a fully occupied valence band separated by an energy gap from the empty conduction band. At room temperature some electrons get thermally excited into the conduction band leaving holes in the valence band. Semiconductors can also be doped either with electron-donor atoms (N type) or electron-acceptor atoms (P type).
The LED light is created near a N-P junction and comes from N region electrons pushed into the P region in the conduction band recombining with the holes in the valence band there and vice versa. The energy of the photon is equal to the energy gap of the given semiconductor +/- thermal energy of the electrons and typically is more than 2 eV.
The 0.7 V is a typical forward voltage of a silicon diode. For most LED material, the forward voltage is larger but not quite equal to the photon energy. Extra energy comes actually at the ohmic contact with the leads.
Metals can't produce light because they have a different electronic structure. Simple metals, like sodium, copper, gold, have the one, half-occupied energy band. The atoms of these elements only one valence electron and when they form a solid, the valence level splits into a band with room for twice as many electrons as there is atoms in the solid. That's why it is only half occupied. You can accelerate electrons there by field, but they quickly lose the energy due to collisions. They can never gain enough energy to be able to emit a photon of a visible light.
Related to Where does the energy in LED come from?
1. Where does the energy in LED come from?
The energy in LED comes from the movement of electrons in a specific type of semiconductor material. When an electrical current passes through this material, the electrons release energy in the form of photons, which creates the light emitted by the LED.
2. How does an LED produce light?
An LED (light-emitting diode) contains a semiconductor material which is doped (treated) with impurities to create a p-n junction. When an electrical current is applied to the LED, the electrons in the p-n junction are excited and move to a higher energy level, releasing energy in the form of photons which we perceive as light.
3. Is LED energy efficient?
Yes, LED technology is highly energy efficient. LEDs use only a fraction of the energy that traditional incandescent or fluorescent bulbs use to produce the same amount of light. This is because LEDs convert almost all of the energy they consume into light, while other types of bulbs produce a significant amount of heat energy as well.
4. What is the lifespan of an LED?
The lifespan of an LED can vary depending on the quality and usage of the bulb, but on average, LEDs can last anywhere from 20,000 to 50,000 hours. This is significantly longer than traditional bulbs, making LEDs a more cost-effective and environmentally friendly choice for lighting.
5. How does the color of an LED affect its energy usage?
The color of an LED is determined by the semiconductor material used in the p-n junction. Different materials produce different colors, but the energy usage of an LED is not significantly affected by its color. However, some colors may appear brighter or use more energy due to the composition of the material used.
  • Other Physics Topics
  • Electrical Engineering
  • Atomic and Condensed Matter
  • Quantum Physics
