Where Does the Energy of Redshifted Light Go?
  • Thread starter Thread starter JuanCasado
    Energy Light
Redshifted light loses energy as it travels through the expanding universe, raising questions about where that energy goes. Energy is not necessarily conserved in General Relativity, which allows for scenarios where energy loss occurs without violating conservation laws. The discussion highlights that while photons lose energy due to redshift, this can be understood through the conservation of the stress-energy tensor in a comoving volume. Additionally, the possibility of thermalization of light in different media is explored, with examples like the Sunyaev-Zel'dovich effect illustrating how low-frequency light can gain energy. Ultimately, the isotropy of the Cosmic Microwave Background (CMB) and its anisotropies support the hot dense early universe model, ruling out alternative theories that do not align with observed data.
JuanCasado
45
Light traveling across the universe is red shifted, so that it loses energy. Is that energy destroyed? If not, where does it go? Could it be driving the expansion of the universe?
Could light be thermalised, i.e. could a low frequency light increase its energy by passing through a hot enough, although transparent, medium? Or vice versa...
Space news on Phys.org
There is no energy lost in a red shift, just as there is no energy lost if you are in a car accident where you hit another moving car from behind. Kinetic energy is simply frame of reference dependent.
There are multiple ways to answer this question. You can answer it by noting that energy need not be conserved in General Relativity: GR forces the conservation of the stress-energy tensor, which includes energy, momentum, pressure, and anisotropic stresses. Conservation of this tensor as a whole forces non-conservation of energy, under certain circumstances.
Another way of looking at it is to pay attention to the gravitational potential energy as well as the energy in matter fields, by looking at the Hamiltonian formalism. In that case, energy is always conserved by construction. For the case of photons, you'd see the energy loss in the photon field in a comoving volume as stemming from a gravitational potential energy that becomes less negative. For the case of a cosmological constant, you'd see the energy gain in the cosmological constant in a comoving volume as stemming from a gravitational potential energy that becomes more negative.
For a more detailed read:
http://math.ucr.edu/home/baez/physics/Relativity/GR/energy_gr.html
Do you have an example where local conservation of stress-energy implies local non-conservation of energy and/or momentum?
Chalnoth said:
Another way [is..] looking at the Hamiltonian formalism. In that case, energy is always conserved by construction. For the case of photons, you'd see the energy loss in the photon field in a comoving volume as stemming from a gravitational potential energy that becomes less negative. For the case of a cosmological constant, you'd see the energy gain in the cosmological constant in a comoving volume as stemming from a gravitational potential energy that becomes more negative.
Could you clarify that a bit? I would have thought such a potential energy would depend on the configuration of (a spacelike slice of) the spacetime, independent of whether the universe is in (cosmological constant driven) accelerating expansion or coasting expansion or even contraction?
Simply looking at photon red shift there is energy loss obviously. But photon has traveled longer than expected compared to no space expansion case, which I can not relate to energy.
The example in JuanCasado's post works here. Just take a uniform gas of photons. The number density in a local co-moving region stays the same (since it's uniform, the number going into the local co-moving region equals the number exiting it), but if space is expanding, then the photons are getting stretched along with space, and so the energy density in a local co-moving region drops with time.
Quick note on what co-moving means: the size of the region you're looking at expands along with the universe.
How does this work in the context of the conservation of the stress-energy tensor? Well, with a uniform radiation fluid, there are no off-diagonal elements. There's just energy density in the time-time component, and pressure along the space-space components. Since the pressure of a photon gas is 1/3rd its energy density, and since it's uniform in all directions, the diagonal elements of the space-space part are all rho/3, where rho is the energy density of the photons. You can express the conservation of stress-energy in the following form:
\dot{\rho} = -3H\left(\rho + p\right)
Since p = \rho/3, and expanding the derivatives with respect to time:
\frac{d\rho}{dt} = -4H\rho
We can change all of our derivatives with respect to time to derivatives with respect to a by setting:
\frac{d}{dt} = \frac{da}{dt}\frac{d}{da} = a H \frac{d}{da}
So that we have:
aH\frac{d\rho}{da} = -4H\rho
\frac{d\rho}{da} = -\frac{4}{a}\rho
\frac{d\rho}{\rho} = -4 \frac{da}{a}
\ln\left(\rho\right) = -4 \ln\left(a\right) + C
\rho(a) = \rho(0) a^{-4}
Since the volume is increasing as a^3, but the energy density is falling as a^{-4}, this represents an energy loss per unit volume, taken directly from the conservation of stress-energy and making use of the fact that p = \rho/3 for photons.
Note that you can follow this process in the exact same way for any form of matter where p = w\rho with w = constant. For w = 0, energy is conserved in a comoving volume. For w < 0, energy grows with expansion. For w > 0, energy drops with expansion.
v2kkim said:
Simply looking at photon red shift there is energy loss obviously. But photon has traveled longer than expected with no space expansion, which I can not relate to energy.
Huh?
Chalnoth said:
Huh?
Actually my wording was not good so I modified a little. I meant photon travel more than 'c' due to space expansion.
Oh, well, no. The only relative speed that has any meaning in general relativity is local relative speed. A photon always travels at speed c relative to any local observer, irrespective of the expansion.
Chalnoth said:
The number density in a local co-moving region stays the same [..], but if space is expanding, then the photons are getting stretched along with space, and so the energy density in a local co-moving region drops with time. Quite note on what co-moving means[..]
Oops, it seems you need a quick note on what "http://en.wikipedia.org/wiki/Local_reference_frame" " means in general relativity. How about we drop this point (hint: locally is where GR conserves the stress-energy tensor, and it actually does require that energy and momentum are locally conserved individually) and we move straight on to you clarifying your claim regarding the balancing of potential energy?
Well, if you're going to reduce all the way to flat Minkowski space-time, then you can't talk about the effects of the expansion. So I took one step up from pure locality: a local comoving volume. This is localized in space, but not in time, so that the space-time curvature has an impact.
You haven't proven that the stress-energy tensor is conserved (whatever you mean by that) for your comoving volume.
Was your statement about balancing potential energy also incorrect?
No. I made use of the equation that can be derived from conservation of the stress-energy tensor:
\dot\rho = -3H\left(\rho + p\right)
You can go ahead and go through the covariant derivative of the stress energy tensor of an isotropic, homogeneous fluid if you'd like (it's a bit much to put down in tex for a forum post). But the equation above is what you get.
No.
As far as I have seen, the second part of my question has not been discused:
Yes. This is the nature of the Sunyaev-Zel'dovich effect, which can be used to detect galaxy clusters (which contain a very hot gas that "warms up" the CMB photons).
Good. So, could CMB photons be (conversely) red shifted, i.e. "cooled down", due to interactions with very cold intergalactic media?
Perhaps. But there isn't much of anything that cool out there.
Well, any intergalactic particle should be in thermal equilibrium at about 2.7K, right?
Not necessarily. There's also starlight to consider, which tends to heat up the IGM above the CMB temperature.
Not much I'm affraid. Could we agree in the 3K level?
It's significant enough to cause the IGM to be ionized. But regardless, even if the IGM were at the temperature of the CMB, it couldn't cool it down.
At this point, what observational constraints can rule out the following idea?:
Since the universe is full of photons randomly flowing in all directions that, after long enough times, become in thermodinamic equlibrium with IGM, the CMB could be the result of photons thermalised to its lowest temperature.
But the problem is that the IGM isn't in thermodynamic equilibrium. It's ionized by starlight (and therefore also warmer than the CMB).
No energy loss, redshifted photons are merely smeared out over a longer time interval [think time dilation].
Well, there are all sorts of different ways to look at it. And yes, energy loss is one of those ways.
The isotropy of the CMB would not be re-produced by this process (the temperature is the same in all sight lines to a very high degree of accuracy).
In addition the very small anisotropies that we do see, have a angular power spectrum very well predicted by the 'hot dense early universe' hypothesis (see http://background.uchicago.edu/~whu/beginners/introduction.html://" for a thorough introduction with lots of animations). An alternative proposal such as your would need to also make the same very specific predictions that this model does to be a contender.
Since this spectrum is observed, then if your model doesn't predict it then it is ruled out.
No. My understanding is that such a process would not give such a perfect blackbody spectrum.
Cheers -- Sylas
Cheers -- Sylas
Why not?
Cheers
Any literature reference on your sentence?
Agreed.
Thank you for your help.
  • #31
JuanCasado said:
Why not?
Cheers
Basically, almost any process removing energy from photons is going to distort the spectrum, unless there is a very special relationship between the energy of photons and the energy they loose. The real onus is on anyone wanting to demonstrate some physical process that somehow could remove just the right amount of energy from photons to maintain a blackbody.
Photons in a blackbody spectrum are distributed over the whole spectrum. If thermalized with matter, the colder photons will tend to heat up, and the hotter ones cool down, so that the spectrum is bound to be distorted.
This is observed... through in reverse. Background radiation is extremely cold, and so in its interactions with matter the tendency is for the photons to pick up energy from the interaction. It's called the Sunyaev-Zel'dovich effect, in which interactions with hot matter give a blueshift. This distorts the spectrum away from a blackbody, as we should expect. The same thing would occur in reverse with compton cooling of radiation, which is why we cannot get a cold blackbody spectrum by cooling hot radiation using interactions with cold matter.
Cheers -- Sylas
  • #32
  • #33
time dilation resolves the apparent energy loss - lower energy photons are received over a longer period of time. the result is the same. how hard is that to understand?
  • #34
Well, as I said, there are multiple ways to look at it. If we consider, for instance, the photons within a comoving volume, the number density will stay the same with the expansion, but their wavelength will get larger, resulting in a lower energy in an expanded volume than before expansion.
  • #35
from the perspective of any given observer, the redshifted photons will persist over a long periond of time. the total energy will be preserved.
  • #36
That's just not the case though. Not unless you use the Hamiltonian formalism which includes gravitational potential energy, that is. Just a simple example shows this is so: the energy density in photons now is non-zero (though pretty small compared to matter). Fast forward to the asymptotic future assuming the universe continues to expand, and the total energy in photons any volume you pick will be zero.
  • #37
Well, I was not referring to hot plasma among galaxies within a cluster, but to very cold matter in the voids among the clusters...
  • #38
I understand that; and specifically allowed for it in my explanation for why it can't explain the CBR. Repeating what I said before:
sylas said:
... The same thing would occur in reverse with compton cooling of radiation, which is why we cannot get a cold blackbody spectrum by cooling hot radiation using interactions with cold matter.
In interactions with matter, a blackbody spectrum is not preserved. The CMB has a fantastically accurate blackbody spectrum. Therefore the CBR is not some originally hotter radiation that has been cooled (redshifted) by comptomization -- which is what you are asking about.
It is all the same process; energy transfer between radiation and matter, when there is a temperature difference. It's known and studied. The process of "compton cooling" and "compton heating" are the same physical process, and it does distort a blackbody spectrum. You are proposing "compton heating" (which means hotter matter and a cooler radiation temperature). It's a neat idea, but it can't work for explaining the CBR.
Cheers -- Sylas
  • #39
I perceive a misunderstanding of general relativity. Do you have any particular math in mind, Chalnoth? I do.
  • #40
But why would you think that matter is very cold? Certainly it's not as absurdly hot as the matter within clusters, as that matter has been heated up by falling into the large gravitational potential wells. But it still tends to be ionized due to starlight.
  • #41
You do realize that energy is not always conserved in General Relativity, right?
  • #42
Only if that medium were colder than the CMB, which isn't the case.
  • #43
What is the temperature of that medium?
  • #44
Cheers -- Sylas
Thanks for the details. In fact I was proposing cooler matter and hotter radiation. Any references supporting the "distortion" you mention?
  • #45
What I mean is that you are proposing radiation that gets colder, and matter that gets hotter, as a result of the interaction.
I've already given you the key terms to look for, though unfortunately they are only for the case where cold radiation is made hotter. Here's a page on the Sunyaev-Zel'dovich Effect which includes a diagram illustrating the distortion for this case. Here's the diagram:
The rightward shift is the heating effect on the radiation; the distortion is the small change in shape you can see. It diverges from the blackbody spectrum.
What you are proposing is the same physical process, but in reverse, with cold matter. And I don't know of a corresponding diagram, nor even of a case where it is measured. It may be that at such cold temperatures the effect becomes less, well, effective. I'm not sure. It would have to be very cold indeed, because the CMBR is only about 2.7 degrees above absolute zero.
Cheers -- Sylas
  • #46
Cheers -- Sylas
Do you realize that in the figure quoted "the SZE distortion shown is for a fictional cluster 1000 times more massive than a typical massive galaxy cluster", so that the effect I am proposing will be practically null and would yield an spectrum undiscernible from a blackbody spectrum?
Regards
  • #47
Regards
Of course I do realize the SZE effect is small.
But no, the effect you are proposing is NOT nearly null. You are proposing a very large effect indeed! That's another tremendous physical difficulty with invoking matter interactions. The problem is to explain a very cool background radiation, showing the spectrum of a thermodynamic blackbody at a fantastically cold 2.7 degrees above absolute zero.
The conventional explanation is that cosmic microwave background radiation is from a source that is at about 3000K; but redshifted by a factor of about 1100 from the cosmological redshift -- the same process that gives a redshift to distant galaxies. This works, because redshift from an increase in the scale factor does preserve a Planck spectrum. This can therefore account for the large shifts needed to give a very cold CMBR.
You have suggested an alternative; that it comes from some hot source, and has been cooled, not by processes connected with velocity or gravitation or scale factor, but by interactions with matter. The effect has to be very large, because the radiation is very cold.
Interactions with matter will distort a Planck spectrum. If there is any significant level of cooling in the radiation, there will necessarily be a correspondingly significant distortion of the spectrum.
You've actually hit here upon another reason to think interactions with matter won't work. As you note, interactions with matter tend to have a very small effect indeed. That only makes it harder to find sufficient time and matter to cool hot radiation down by the large amounts you require. In fact, this might be a better way to help you see why interactions with matter are physically not able to account for the CMBR.
Cheers -- Sylas
  • #48
It's not well-described by a single temperature, as it's not in thermal equilibrium (as I said, it's ionized by stars).
Oh, and by the way, the result of this cooling wouldn't be a thermal spectrum either. The CMB has an almost perfect blackbody spectrum.
