I Where does the Sol system lie in the cross-section of the Orion Spur?
Sol is located approximately 25,000 light-years from the galactic core and is estimated to be about 50 light-years above the galactic plane, placing it roughly central within the Orion Arm. The discussion explores the spatial orientation of Sol in three dimensions, particularly its height relative to the "surface" of the Orion Spur. This positioning affects the understanding of nearby celestial bodies and their relation to the galactic rim. The inquiry stems from a desire to create a crude map of space-faring factions, highlighting the complexities of accurately mapping the galaxy. Ultimately, Sol's central location within the arm suggests a significant role in the spatial dynamics of the surrounding region.
AotrsCommander
So, I know that Sol lies roughly in the 25 000 light years from the core and from the edge of the galaxy and thus the approximate the position when seen from "above." But what a search today has not given me any idea of is where Sol is (thought/estimated to be) in relation to, well, height/depth. I.e. how far it is from the (for want of a better term) "surface" (top/bottom/side?) of the Orion Spur/Arm (as far as can be defined with such a nebulous (aha) boundary). Whether it's near the centre of the radius or the periphery or what. My google-fu has not been able to turn anything up.
The reason I'm asking is more suited for the Lounge in application, but, in short, I am looking at the possibility doing a (very, very VERY) crude map of space-faring factions, basically. This is a task which is in all likelihood, simply impractical for many reasons, not least of which being, well, a practical map of the galaxy that would even stand up to use. But even to make any kind of attempt, I still am lacking in all that much of a spatial "feel" for where Sol is located in the Orion Arm in three dimensions. And thus whether stuff stated to by on "the rim" - jury would be out whether it means the actual outer rim of the galaxy or the "rim" of the arm - could be in relation. If Sol is dead-centre, that is a lot different to it being near the "top" or the "bottom" or the inner side of the arm or what, since that potentially changes what, relative to Sol, the orientation of stuff on the aforementioned "rim."
(Plus, I realized, I just don't KNOW. And that bugs the engineer in me as well.)
Astronomy news on Phys.org
Right, thanks; so if I'm understanding from that correctly, it's currently 50 ly above the galactic plane (so, 450 ly from the "top" (galactic north) of the Orion Spur, and it would eventually reach about half the radius of the arm at it's furthest point in... Extrapolating - something on the order of 12 million years.
(WELL outside the timescales I need to consider, since if I'm around by that point, I'll probably be able to have a galaxy in real time filled in properly and everything...!)
Which would place Sol pretty much central to the arm, then, by a reasonable definition (being within 10% of the radius).
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
