SlurrerOfSpeech
- 141
- 11
I'm trying to solve https://www.hackerrank.com/challenges/summing-pieces and I think I have come up with an O(n) solution although the numbers aren't coming out exactly right. The problem is essentially to find a sum like
ABCD
---> All sets of sets of contiguous subarrays spanning ABCD is
{ {ABCD}, {ABC, D}, {A, BCD}, {AB, CD}, {AB, C, D}, {A, BC, D}, {A, B, CD}, {A, B, C, D} }
---> special sum is
4(A+B+C+D) + 3(A+B+C) + 1(D) + 1(A) + 3(BCD) + 2(AB) + 2(CD) + 2(AB) + 2(C) + 2(D) + 2(A) + 2(BC) + 2(D) + 2(A) + 2(B) + 2(CD) + 2(A) + 2(B) + 2(C) + 2(D)Let me know if you see anything wrong with my attempted C# solution, and I would appreciate any general comments on my coding style.
ABCD
---> special sum is
Code:
using System;
using System.Collections.Generic;
using System.IO;
using System.Linq;
/// <summary>
/// Helper class for finding the sum of elements in a contiguous section
/// of an array in O(1) time.
/// </summary>
public class RangeSummer
/// <summary>
/// _s[i] = arr[0] + ... + arr[i]
/// </summary>
private long[] _s;
/// <summary>
/// Length of _s and arr
/// </summary>
public int Length { get; private set; }
/// <summary>
/// Initializes using the source aray <param name="arr"></param>
/// </summary>
/// <remarks>
/// Initialization takes O(n) time
/// </remarks>
public RangeSummer(long[] arr)
int n = arr.Length;
Length = n;
_s = new long[n];
for (
long sum = 0, i = 0;
i < n;
sum += arr[i], _s[i] = sum, ++i
/// <summary>
/// this[i,j] = the sum of the elements of arr in the range [i, j)
/// </summary>
/// <remarks>
/// Uses the fact that arr[i] + ... + arr[j - 1] = s[j - 1] - s[i - 1]
/// </remarks>
public long this[int i, int j]
get
return i == 0 ? _s[i] : _s[j - 1] - _s[i - 1];
internal class Solver
/// <remarks>
/// The problem useslessly makes us mod our answer by 10^7+9
/// for the final output.
/// </remarks>
private long _divisor = (long)Math.Pow(10.0, 9.0) + 7;
/// <summary>
/// Utility class for fast lookup of sum of elements
/// of source array in a given range
/// </summary>
private RangeSummer _summer;
/// <summary>
/// Single constructor. Since the only purpose of this class
/// is to solve a single problem, class could be made into
/// a functor or could use a similar design pattern.
/// </summary>
/// <param name="arr">Source array</param>
public Solver(long[] arr)
_summer = new RangeSummer(arr);
/// <summary>
/// Wrapper function for recursive solution
/// </summary>
/// <returns>Final answer</returns>
public long GetSpecialSum()
long sum = GetSpecialSum_Recursive(0, _summer.Length);
return sum % _divisor;
/// <summary>
/// Inner function of recursive solution
/// </summary>
/// <remarks>
/// Uses the fact that the solution f({A_0,...,A_n-1})
/// is equal to
/// n * (A_0 + ... + A_n-1) + f({A_1, ..., A_n-1}) + A({A_0, ..., A_n-2})
/// </remarks>
/// <param name="i">starting index</param>
/// <param name="j">1 off-the-end of second index</param>
private long GetSpecialSum_Recursive(int i, int j)
return i >= j ? 0 :
(j - i) * _summer[i, j] // (j - i) (arr[i] + ... + arr[j - 1])
+ GetSpecialSum_Recursive(i, j - 1)
+ GetSpecialSum_Recursive(i + 1, j);
/// <summary>
/// Solution to the HackerRank problem [PLAIN]https://www.hackerrank.com/challenges/summing-pieces.[/PLAIN]
/// This is for testing and debugging locally. The code pased into the solution box will
/// be slightly different since it reads the input from the console.
/// </summary>
class Solution
static void Main(String[] args)
// get test file
string curdir = Directory.GetCurrentDirectory();
System.IO.StreamReader file = new System.IO.StreamReader(
Path.GetFullPath(
Path.Combine(curdir, @"..\..\", "TestFiles\\TestTwo.txt")
) // second line is 4 2 9 10 1
// get input and solve
int.Parse(file.ReadLine()); // don't need this line
long[] arr = Array.ConvertAll(file.ReadLine().Split(' '), long.Parse);
Console.WriteLine(new Solver(arr).GetSpecialSum());
