Where is the gravitational potential energy?
In summary, gravitational potential energy is the energy an object possesses due to its position in a gravitational field and can be measured in joules (J) using the formula PE = mgh. It is stored in an object's position and can be converted into other forms of energy. The location of an object affects its gravitational potential energy as it is dependent on the object's distance from the source of the gravitational field.
bajerrrr
I
am confused on where the gravitational potential energy is in this solution. Thank you
bajerrrr said:
I
Note that they are talking about the KE of the projectile immediately after it leaves the gun. You still need to consider gravitational PE if you want to find the KE at other points. (They are ignoring the small change in height of the projectile as it travels through the gun.)
ok. thank you very much. I was accounting for the small change in height
Related to Where is the gravitational potential energy?
1. What is gravitational potential energy?
Gravitational potential energy is the energy an object possesses due to its position in a gravitational field. It is the energy that is required to lift an object to a certain height against the force of gravity.
2. How is gravitational potential energy measured?
Gravitational potential energy is measured in joules (J) and can be calculated using the formula PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object.
3. Where is the gravitational potential energy stored?
The gravitational potential energy of an object is stored in its position in a gravitational field. The higher an object is lifted, the more potential energy it has stored.
4. Can gravitational potential energy be converted into other forms of energy?
Yes, gravitational potential energy can be converted into other forms of energy such as kinetic energy or thermal energy. This often occurs when an object falls from a height and its potential energy is converted to kinetic energy.
5. How does the location of an object affect its gravitational potential energy?
The location of an object affects its gravitational potential energy because the potential energy is dependent on the object's distance from the source of the gravitational field. The higher an object is lifted, the more potential energy it has. As the object moves closer to the source of gravity, its potential energy decreases.
11K
