Where is the 'Origin' on a Bode Plot?
In summary, the "Origin" on a Bode plot refers to the point where the frequency response of a system begins, typically at a frequency of zero. On a Bode magnitude plot, it indicates the gain of the system at low frequencies, while on the Bode phase plot, it reflects the phase shift at those frequencies. Understanding the origin is crucial for analyzing system stability and response characteristics.
dvscrobe
51
TL;DR Summary
Discussion on Poles and Zeroes
Wasn't sure where exactly to post this. It isn't a homework problem. I am studying for my Fundamentals of Engineering exam and am struggling with control system problems. Can someone tell me where exactly the origin is on a Bode Plot? I understand the general concept of poles and zeroes but I get confused with respect to the origin.
There is no origin. It goes on forever in both axes, like all log-log plots. You only draw the region you care about.
Yet the number line goes from -∞ to +∞, but still has an origin at zero.
A gain of 1 = 0 dB, in Log space.
The Log( 1 Hz ) = 0, in Log space.
So the origin of the Log-Log Bode plot is ( 0, 0 ) = ( 1 Hz, 0 dB ) = ( 1 Hz, gain 1 ).
The confusion arises because the x-axis is labelled in Hz, not the Log of hertz.
As you can see, experienced engineers that use this plot all the time either don't agree or aren't clear on the definitions. So, IMO, the origin doesn't matter. It's the least important thing about these plots. Pick one, move along, nothing to see here...
dvscrobe said:
I was reading through this article. It was very good at explaining the 3rd dimension of the S-plane. The 3rd dimension is the gain. That was an eye opener for me. So, is the origin on the S-plane where the sigma axis crosses the jw axis?
Transfer Function Analysis | Basic Alternating Current (AC) Theory | Textbook (control.com)
yes. In the s-plane, the origin is s=0=0+j0. It's just a plot of complex numbers.
PS: just to clarify, the origin in the (horizontal) s plane is s=σ+jω=0+j0=0. In the third dimension they are plotting the magnitude of the gain, which could create the same ambiguity for the vertical axis as the bode plots if they express it in dB or not. But on this page, and in most all descriptions of this sort, it isn't a log plot and the vertical axis origin is when |G(s)|=0. They didn't label or describe that, but I know it's not a log plot because of the shape of the poles.
DaveE, okay awesome! Thanks. So that definitely answers where the origin is at. I think what confused me is if a pole or zero is not at the origin, then would the bode plot shift over to that spot or remain at the origin. In the article, if you see where they trace it, it is over the origin and extend in the +jw direction. Thanks for help!
You can make that plot however you like. Think of it as a window in an infinite expanse in all directions of log(ω) and dB. You put your window over the areas you care about and label the axes around the edge. The origin is pretty irrelevant. For example, here is the sort of bode plot you'll see in practice:
Likes dvscrobe and berkeman
FAQ: Where is the 'Origin' on a Bode Plot?
What is a Bode Plot?
A Bode plot is a graphical representation of a linear, time-invariant system transfer function. It consists of two plots: the magnitude plot (showing the gain) and the phase plot (showing the phase shift) as functions of frequency.
The 'Origin' on a Bode plot typically refers to the point where the frequency is zero. However, in practical terms, Bode plots usually start at a low, non-zero frequency because a frequency of exactly zero is not plotted.
Why can't we plot the 'Origin' (frequency = 0) on a Bode Plot?
In a Bode plot, the frequency axis is logarithmic, and a logarithm of zero is undefined. Therefore, the plot cannot start at zero frequency and instead starts at a low, positive frequency value.
How do we interpret the 'Origin' in terms of system behavior on a Bode Plot?
Even though we don't plot the 'Origin' (frequency = 0), we can infer the system's behavior as the frequency approaches zero. For example, the gain may approach a constant value, and the phase may approach a certain angle, depending on the system's transfer function.
What are the starting points of the magnitude and phase plots if not the 'Origin'?
The starting points of the magnitude and phase plots are typically at a low, non-zero frequency value, such as 0.1 Hz or 1 Hz, depending on the system being analyzed. These starting points provide a practical approximation of the system's behavior near the 'Origin'.
