Where is the strongest intensity of an electromagnetic field produced by a solenoid?
In summary, the strongest intensity of an electromagnetic field produced by a solenoid is found inside the solenoid itself, particularly in the center. The field strength is uniform and maximized within the solenoid, decreasing rapidly outside of it.
CA_PT
I don't have a strong technical background in this, so need some help. I'm currently investigating pulsed electromagnetic field (PEMF) devices to rehab injuries, and trying to figure out the best applicator and placement.
The choices available are coils, mats, butterfly coils, paddles, and a straight rope. From what I've read so far, it seems like the best way to expose injured body parts to the largest electromagnetic field would be to wrap the body part that requires PEMF treatment with as many turns of the straight rope coil as possible to create a solenoid, and pass as much current through the wire as tolerated.
Based off the inverse square law, it seems like holding any of the other applicators on the skin's surface- when trying to reach tissue at any depth underneath the skin- would be much less effective). Can anyone confirm this?
Welcome to PF.
(emphasis added by me) Are you familiar with Medical Device Safety Standards like IEC 60601? You can't just be experimenting on people without some understanding of the safety standards and a moderate amount of experience with designing and building circuitry...
  • Intertek White Paper on IEC 60601-1-2 Edition 4 Medical Safety Standard.pdf
Likes Vanadium 50 and BvU
Ok, let me re-phrase: PEMF is an FDA-approved device, commercially-available to purchase without physician prescription. To be clear, I'm not building my own machine, or experimenting on people; I don't even own a machine yet.
For the devices that are commercially available, there are multiple applicators available, and there is not much consistent info about them; five different retailers can give you five different opinions about what applicator to use and where to place it. From what I've read about PEMF so far, some of the applicators and placements don't make sense, so I'm just curious about the science behind it.
Appreciate the concern, and I apologize if there was some confusion from my original post. If you have any knowledge to shed more light on the nature of electromagnetic field intensities based on design and location, it'd be greatly appreciated.
Thanks for the clarifications. If you are using un-modified FDA approved devices and applicators, that should be fine.
Have you tried looking for the peer-reviewed papers and clinical trials that resulted in those FDA approvals? It would seem there would be some sort of discussion about the different applicators and what they are best at.
Likes Vanadium 50
I thought you didn't want really high fields with this. In any event, shouldn't you be working with some medical practitioner to determine the best dose?
Likes Delta Prime and berkeman
