Where is x^3 + 12x + 5 increasing and decreasing
In summary, we discussed finding intervals where the function f(x)=-x^3 + 12x +5 is increasing and decreasing. We also looked at the necessary and sufficient condition for extrema using derivatives, which involves checking for a zero derivative and investigating the behavior of the function around that point.
teng125
416
Find intervals on which f(x)=-x^3 + 12x +5 , -3<x<3 is increasing and decreasing. Where does the function assume extreme values and what are these values ?
does anybody knows how to do this??
I have the feeling derivatives may be a good idea :smile:
Do you know a necessary and/or sufficient condition for extrema, using derivatives?
no,pls explain to me
When a function becomes extreme in a point, the tangent line will be horizontal there which means that the derivative of the function is 0 there. Note that this is a one-way argument, an extremum implies a zero derivative but not the other way arround, so this is a necessary condition - though not sufficient.
To check whether it is actually a min or max, you can use the second derivative or investigate whether the function switches from increasing to decreasing or vice versa arround that point.
Related to Where is x^3 + 12x + 5 increasing and decreasing
1. What is the general equation for determining where a function is increasing or decreasing?
The general equation for determining where a function is increasing or decreasing is the first derivative test, where you take the derivative of the function and set it equal to zero to find critical values. These critical values divide the function into different intervals, where the function is either increasing or decreasing within each interval.
2. How do you use the first derivative test to determine where a function is increasing or decreasing?
To use the first derivative test, you take the derivative of the function and set it equal to zero. Then, you solve for x to find the critical values. Next, you create a number line with the critical values and test a value within each interval to see if the derivative is positive or negative. If the derivative is positive, the function is increasing in that interval. If the derivative is negative, the function is decreasing in that interval.
3. Can x^3 + 12x + 5 have both increasing and decreasing intervals?
Yes, x^3 + 12x + 5 can have both increasing and decreasing intervals. This is because the function can have multiple critical values, which creates different intervals where the function can either be increasing or decreasing.
4. How do you determine if a critical value is a local maximum or minimum?
To determine if a critical value is a local maximum or minimum, you can use the second derivative test. You take the second derivative of the function and plug in the critical value. If the second derivative is positive, the critical value is a local minimum. If the second derivative is negative, the critical value is a local maximum.
5. How does the graph of x^3 + 12x + 5 reflect its increasing and decreasing intervals?
The graph of x^3 + 12x + 5 reflects its increasing and decreasing intervals by having a positive slope in the increasing intervals and a negative slope in the decreasing intervals. The critical values also represent points where the graph changes direction from increasing to decreasing or vice versa.
