Where must a third charge be placed to get a net force of 0
In summary: So the equation should be (A/x^2) - (B/ (3d-x)^2) =0. The first two don't qualify because the forces are not equal in the first two regions, but I'm still not sure how to solve that equation.If the third, I do not see how you can imply it is wrong merely by checking some other distance > 2d.In summary, the conversation discusses a problem involving the placement of three charges in a coordinate system. The solution suggests that the third charge must be placed at a distance greater than 2d from the origin in order for the net force on it to be zero. However, the poster is having difficulty understanding how this conclusion was reached and is
Perseverence
88
A charge of +2 Q (A)is placed at the origin of a coordinate system and a charge of - Q (B) is placed at a distance d from the origin. How far from the origin must have 3rd charge +Q (C) be placed so that the net force on it is zero Newtons.
Fe=kQq/r^2
The solution to this question says that the Third charge must be placed greater than 2d distance away from the origin.
I tried to solve this problem by finding a distance that would make the absolute value of the force of A on C equal the force of B on C. Making the distance that the Third charge is place morevthan 2d just does not make these forces on C equal. For example placing the Third charge at 3D makes the charge A on C : B on C have the ratio of 2/9d^2 : 1/4d^2. That doesn't seem to make the net force on charge C = zero to me
There is a possibility that the book solution is wrong (typo, relates to a previous version of the exercise, etcetera). Why don't you work out your own solution and verify that it is correct.
Trial and error is a start, but for an answer you should write an equation that you can solve: place C at position x on the AB axis and set up an expression for the force. Does the charge of C matter ?
I did try several different distances. In the example above that I listed I tried 3D which should have worked as an answer but it did not. The answer in the book says that a distance greater than 2D should make the net force equal to zero. The charge on C does matter. It is listed as q+. The amount and sign on the charge explains whether or not the other two charges will be attracted or repulsed by charge C.
So are you telling me that the answer in the book is wrong? And that I should disregard it?
I am asking you to write an equation and see if you can solve it...:rolleyes:
Please clarify... Does it state a specific distance, and you are telling us that it is greater than 2d, or does it say that any distance > 2d will do (surely not), or that it tells you the distance is greater than 2d without specifying exactly what it is?
I actually work out an equation with 3d. You can see it in my original post
Yes. Now the correct equation, please:
Force at postion x from +2q + Force at position x from -q = 0
How do I attach a picture of the question? I'm only seeing options to add a link to a url
The answer is literally " greater than 2 D" I understand that. Doesn't necessarily mean that any value greater than 2D would be the answer, but I still have no idea how they came to that conclusion mathematically.
Ok. I was able to track down the answer as 3.41d (p286, #22) which apparently can be derived quadratically, but I have no idea how they did that. Any insight?
Apply your own relevant equation
"Greater than 2d" is a hint: there are three regions (left, between, right, if you place the -q at ##x=d##). The first two don't qualify (why not?) so you have to find the solution on the right.
I still don't understand, because the equation that would give the answer seems to have two variables.( A/(xd) ^2) -( B/(yd )^2) = x and y are not the same number. I've obviously thought about this a lot and I'm extremely frustrated. Is there any chance you could just tell me how they got to the answer 3.41 d quadratically?
Sorry. My above post had an error instead of the last X the equation should equal 0
+2q is positioned at the origin.
-q is is positioned at ##x=d##.
Your test charge is positioned on the x axis. What is the force (a vector with magnitude, direction) the +2q exerts on the test charge as a function of x?
Same question for the force from the -q . Add them up, set to 0 and voila...
How can I calculate the force charge A or charge B will have on the Third charge without knowing what the distance of the 3rd charge is from charge A and charge B? It's required in the formula to know what r squared is to calculate Force. Without knowing the distance that they are from the Third charge how do I know what force they have on it?
You keep saying to calculate the force that each charge has on the test charge, but I can't calculate force on the test charge without knowing its distance from the test charge.
Come on !
What is the distance between two charges if one is located at the origin and the other is at position ##x## on the x-axis ?
Ah! Did you already conclude from symmetry that the solution is to be found on the x-axis ?
The distance between the first and second charge is x. It still doesn't tell me where the Third charge will be located.
BvU said:
Come on !
="BvU, post: 5967703, member: 499340"]+2q is positioned at the origin.
Same question for the force from the -q . Add them up, set to 0 and voila...[/QUOTE]
BvU said:
Come on !
If the test charge is placed at 2d then it would feel (1/2d^2)-(1/d^2) = -1/2d^2. So I guess they are technically saying that it would have to be further away than 2d to overcome feeling this negative force (.-1/2d^2.) But it still doesn't explain how they got to 3.41d quadratically
Please please please answer the question
So we can deal with your inhibition in post #16 and continue from there.
Perseverence said:
The distance between the first and second charges is x.
Good.
Now: what is the distance between two charges when the first is placed at ##x=d## and the second at ' ##\ x=x\ ## ' (where ##x>d##)
Related to Where must a third charge be placed to get a net force of 0
1. What is the equation for calculating net force on a charge?
The equation for calculating net force on a charge is Fnet = F1 + F2 + F3 + ... + Fn, where F represents the individual forces acting on the charge and n represents the number of forces.
2. How do I determine the direction of the net force on a charge?
The direction of the net force on a charge is determined by the vector sum of all individual forces acting on the charge. If the individual forces are in opposite directions, the net force will be in the direction of the larger force.
3. Can the net force on a charge ever be zero?
Yes, the net force on a charge can be zero if the individual forces acting on the charge cancel out each other's effects. This can happen when the charges are arranged in a way that the forces they exert are equal in magnitude and opposite in direction.
4. How can I find the position where a third charge must be placed to get a net force of zero?
To find the position where a third charge must be placed to get a net force of zero, you can use the principle of superposition and set the equation for net force equal to zero. This will give you the position where the third charge should be placed to achieve a balanced force.
5. What factors can affect the net force on a charge and its position?
The net force on a charge can be affected by the magnitude and direction of the individual forces acting on it, as well as the distance between the charges. The position of the third charge to achieve a net force of zero can be influenced by the relative positions and magnitudes of the other two charges.
