MHB Where Should I Begin with Parabolas?
  • Thread starter Thread starter Ilikebugs
    Parabola
The discussion focuses on understanding the properties of parabolas, specifically the axis of symmetry and the minimum value of a quadratic function. The axis of symmetry for the function y(x) = 5x^2 + ax + b is determined to be x = -a/10. Using this, the minimum value of y is calculated as y_min = -1/5. The participants confirm that a unique solution to the system of equations is found with a = 0 and b = -1/5, leading to the conclusion that the minimum value of the function is indeed -1/5. The calculations and reasoning are validated through collaborative discussion.
Ilikebugs
View attachment 6358 I don't know where to start :s
Mathematics news on Phys.org
We know the axis of symmetry for the general quadratic:
$$f(x)=ax^2+bx+c$$
is the line:
$$x=-\frac{b}{2a}$$
And so for the given function:
$$y(x)=5x^2+ax+b$$
The axis of symmetry is:
$$x=-\frac{a}{10}$$
And so the minimum value of $y$ will be:
$$y_{\min}=y\left(-\frac{a}{10}\right)=5\left(-\frac{a}{10}\right)^2+a\left(-\frac{a}{10}\right)+b=\frac{20b-a^2}{20}$$
Now, we are given two points on the parabola, and using this data, we obtain:
$$5a^2+a(a)+b=b$$
$$5b^2+ab+b=a$$
Bearing in mind that $a\ne b$, can you obtain a unique solution to the above system?
a is 0, b is -1/5
Ilikebugs said:
a is 0, b is -1/5
Yes, that's what I got too. (Yes)
So then, what is $y_{\min}$?
-1/5?
Ilikebugs said:
-1/5?
That's correct.
Alternatively, we have
$$b=5(a)^2+a(a)+b\implies a=0$$
Substituting $-\frac{a}{10}=0$ for $x$ into $y=5x^2+ax+b$ gives $y=-\frac15$ as our minimum.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
