Where to find experimental data?
In summary, the conversation centers around finding experimental data on complex systems, such as triatomic molecules, and the importance of relying on previous models and theories when studying these systems. The use of different techniques, such as spectroscopy and NMR, to gather information about the structure of molecules is also mentioned. There is also a discussion about the role of experiments in understanding physical systems and the importance of having confidence in previous experimental results. Finally, the conversation touches on the concept of simplicity in physics and the role of textbooks in presenting both theoretical concepts and experimental results.
jonjacson
447
38
Hello folks,
When you study a pendulum or the path followed by a ball falling under gravity the first thing you have in mind is the experimental result, because you can actually see it. It is easy to measure or find the position and velocity of those systems. If we talk about a particle with position, mass and velocity we have enough information to predict his movement.
When you study quantum mechanics frequently you read about Hilbert infinite spaces, differential equations, , eigenvalues, eigenvectors, imaginary numbers, integrals, operators, matrix calculus, but, Where is the data?
To make this clear, let's talk about a triatomic molecule, something like our solar system with two planets. Let's say we have 3 protons in the nucleus and 3 electrons. Where can I find the experimental data on this system? What is the total list of observables that is possible to meassure?
I mean, I know from spectroscopy you can measure the difference between energy levels. And from x ray difraction you can learn about its structure, What about the "eigenstates"? Can I measure the "eigenstates"?
We have energy levels, with stern gerlach experiments I guess you can measure spin too. What else is measurable?
My goal is to have first the experimental data, and only then reading about this or that model "hartree fock" and so on.
I don't like to read about a simplifying model before actually knowing the experimental result, it looks completely absurd to me.
jonjacson said:
To make this clear, let's talk about a triatomic molecule, something like our solar system with two planets. Let's say we have 3 protons in the nucleus and 3 electrons. Where can I find the experimental data on this system? What is the total list of observables that is possible to measure?
A molecule is not like a solar system, and "3 protons in the nucleus and 3 electrons" don't make a triatomic molecule.
In addition to absorption spectra (mostly IR and VIS-UV), you can have things like mass spectrometry and NMR to gain information about the structure of molecules.
No, you can't measure eigenstates directly, only transitions between them. But at one point, the structure of the spectrum gets so complicated that having a model that reproduces it gives you very good confidence that the model is good, especially when it is transferable to a myriad of different molecules.
At one point, you have to rely on what others have done before and assume they were correct, otherwise you will not get far. I could show you the ro-vibrational spectrum of Cl2. What would you do with it? It would simply a wiggly line if you don't already have a model to understand what it can mean.
When I teach the subject, I start by presenting the theory, in a sense asking the students to have confidence in me that I am telling them something correct, then show them some spectra where the features of theory can be observed. But things like the Hartree-Fock method can't easily be "proven" by looking at an experimental spectrum.
The example you gave was "a pendulum or the path followed by a ball falling under gravity". Do you realize how incredibly much simpler these things are than the spectrum of a molecule? Didn't you at one point accepted that Maxwell's equation were correct, used them to calculate things, and then compare to experiments?
I know it is not the same, it is just to put an example on the table.
Thanks for that, (NMR...) I will have a look.
Of course I don't plan to "solve" this problem, it is just that I want to have a look at experimental data.
I realize how simpler it is, but the concepts are always the same. If you have a physical system, experiments, asking nature, or measure it is most important.
Well I readed Faraday before.
A good textbook will have frequent presentation of experimental results. On example is Demtröder's Atoms, Molecules and Photons.
Likes jonjacson
It looks interesting. Unfortunately hi has 4 volumes on experimental physics but it is in German. :(
In the book I mentioned, there are some descriptions of experiments results.
Likes jonjacson
jonjacson said:
Hello folks,
There appears to be a fallacy that one can actually make sense of "experimental data" without actually knowing (i) the actual physics surrounding the experimental technique being used and (ii) the physics that is relevant to that data. This is no different than amateurs clamoring to want to see data on climate change, thinking that a conclusion can be THAT obvious simply by looking at the data without understanding the science behind it.
For example, if I give you the spectroscopy done for NH3 (ammonia), will you actually be able to pick out the effect that is a direct consequence of the superposition of states for the N atom in the molecule?
As for the answer to your question, why can't you google for it? Have you even done a search on various journals? Have you done Google Scholar search?
Zz.
Zz.
Why is that I only get negative answers and critics when I ask for simple experimental data? Is this normal?
XXi century physics, the physics without real data.
Of course I have done a research but I am not sure if I have found the whole complete set of data that is possible to be observed.
First of all, let me be VERY clear to you on who I am. I am an experimentalist! So before you go off on the deep end about your ignorant idea about physics, pay attention to what I was telling you!
Secondly, there is no such thing as a "complete set of data"! You look for the property that you want and go find the relevant experiments that measure THAT property. And note that I said "experiments". Very often, several different experiments measure the SAME thing in different ways.
And no, I have no idea what kind of "research" you have done and on what, because you didn't give a list of what you found.
BTW, if I give you this:
https://arxiv.org/pdf/cond-mat/9904449.pdf
and tell you that Fig. 1 and 2 are the "data", how would you find this of any use? Are you under the impression that people will do a dump of their tons and tons of raw numbers online or in their publication? Is this what you mean by "data"?
Zz.
Likes jim mcnamara
Related to Where to find experimental data?
1. Where can I find experimental data?
Experimental data can be found in various places, such as scientific journals, government databases, and online repositories. It is important to carefully evaluate the reliability and credibility of the source before using the data for your research.
2. How can I access experimental data?
Many experimental data sources are freely available online, while others may require a subscription or payment. It is also common for researchers to make their data available upon request, so reaching out to the authors of a study or contacting the organization that conducted the research may also be an option.
3. What types of experimental data are available?
Experimental data can include a wide range of information, such as numerical measurements, images, videos, and observations. The type of data available will depend on the nature of the experiment and the methods used to collect it.
4. Are there any restrictions on using experimental data?
Some experimental data may have restrictions on its use, such as copyright or licensing agreements. It is important to check the terms and conditions of the data source before using it in your own research.
5. How can I ensure the accuracy of experimental data?
To ensure the accuracy of experimental data, it is important to use reputable sources and verify the data through multiple independent studies. It is also important to critically evaluate the methods used to collect the data and any potential biases that may have influenced the results.
  • Other Physics Topics
  • STEM Career Guidance
  • Atomic and Condensed Matter
  • Chemistry
