Where to place a fan along a duct?
  • Thread starter TSN79
  • Tags
    Fan
In summary, the conversation discusses the positioning of a fan along a circular horizontal duct and whether it affects the fan's operation or if it is only dependent on the total length of the duct and friction. The conversation also mentions the importance of pressure differentials (ΔP values) in certain scenarios and the impact of leaks on the pressure inside the duct. It is stated that for certain situations, the positioning of the fan does not matter, but for others, it may be necessary to arrange the pressure inside the duct in a specific way to ensure proper ventilation and avoid contamination or damage.
TSN79
424
Picture a circular horizontal piece of duct, open at each end. If a fan is to be placed somewhere along the duct and move a certain amount of air, does it make a difference for the fan and it's operating point where it is positioned? Or does it only come down to the total length of duct and the friction it creates?
What are the ΔP values?
It's just a pictured scenario, but typically 1-2 Pa/m in the situations I deal with.
For what you described, no, it does not matter. If there are other factors you aren't telling us about though, it might.
If there are any leaks in the duct you will want to arrange the pressure inside so that the leakage is in an acceptable direction. For example in the duct-work for an airplane shore cooling system the fan must be at the inlet (positive pressure) even if rigid ducting were used as the leaked ambient air is polluted by engine exhaust and is also the wrong temperature.
If the duct is used for transporting particulates then the fan must be at the outlet (negative pressure) otherwise the transported materiel will be sprayed out the leak.
BoB
Related to Where to place a fan along a duct?
1. Where should the fan be placed along the duct?
The fan should be placed in a section of the duct that is straight and free from any bends or obstructions. This will ensure that the fan is able to operate efficiently and effectively.
2. Is it better to place the fan at the beginning or end of the duct?
It is generally recommended to place the fan at the end of the duct, closer to the point where air is being exhausted. This allows the fan to push the air through the entire length of the duct, rather than just a portion of it.
3. Can the fan be placed on a bend or elbow in the duct?
No, it is not recommended to place the fan on a bend or elbow in the duct. This can cause the fan to work harder to push air through the curved section, leading to reduced efficiency and potential damage to the fan.
4. What is the ideal distance between the fan and the nearest obstruction?
The ideal distance between the fan and the nearest obstruction, such as a wall or ceiling, is approximately twice the diameter of the duct. This allows for proper air flow and prevents any back pressure on the fan.
5. Can a fan be placed in a horizontal duct?
Yes, a fan can be placed in a horizontal duct. However, it is important to ensure that the fan is properly supported and secured to prevent any vibrations or movement that could affect its performance.
  • Mechanical Engineering
  • Other Physics Topics
