Where to purchase a 1.7 GHz Oscillator
  • Thread starter Thread starter hashmos
    Oscillator
Several companies manufacture 1.7 GHz oscillators, particularly for defense applications, which can be costly. Suggested manufacturers include Macom, Herley, Miteq, and Microsource, with some older models available on eBay at lower prices. The oscillator is intended for use with a horn antenna, requiring a stable output of 25 watts to minimize attenuation. A typical setup involves an LO chain or synthesizer feeding into a power amplifier, as achieving this output level is challenging with standard lab amplifiers. The discussion emphasizes the need for a specific frequency and wide input range without frequency alteration.
hashmos
Hi guys,
I was just wondering of there is any companies that manufactures a 1.7 Ghz oscillators ?
For the thing I need, I have a stable supply of voltage and I need a specfic frequencey, the one mentioned above. So a VCO, I think, is not the solution as some of you may suggest.
Please, if you now companies that do manufacture them I would greatly appreciate your help,
thanks
hashmos said:
Hi guys,
thanks
What is the application? What power level?
Well the output of the oscillator will be connected to a horn antenna, and from its characteristics, the least attenuation occurs at this frequencey.
I prefer that the oscillator have a wide range of inputs and produces a correspnding output, with the freq. unchanged.
If you want a specific value, then it would be 25 watts as an output.of the oscillator.
A typical scheme is to have an LO chain or a synthesizer, and then feed it to a power amp.
there is many manufactures making these for defense, and they are quite expensive, try googling. But on ebay, you many find oscillators that are not manufactured anymore for a fraction of the cost.
some of the manufactures I'm familiar with:
macom, herley, miteq or microsource.
I don't know if they are still making "microwave bricks" that you get for any frequency.
25 W is equal to 44 dBm, that is LOT of power for a microwave circuit. You can certainly buy power amplifiers that can do this (you can buy amplifiers meant for e.g. radar that will give you kW of power); but it is well outside what you can get out of a typical "lab" amplifer (they will typically give you 15 dBm at most).
Hence, an amplifer like this is likely to be quite expensive.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 16 ·
11K
  • · Replies 21 ·
  • · Replies 16 ·
