Where was the cue ball struck to initiate rolling without slipping?
  • MHB
  • Thread starter Jameson
In summary, the optimal location to strike the cue ball to initiate rolling without slipping is in the center or slightly above center. Striking the ball off-center can result in sliding or spinning, leading to an inaccurate shot. There is no specific angle for striking the cue ball, but aiming for the center is important. Any type of cue ball can achieve rolling without slipping, but some materials may affect its movement. To consistently achieve this type of shot, proper cue ball control and a consistent stroke are key.
Jameson
MHB
4,541
** Today is a big milestone for our POTW contest! We've been doing this for 1 year now without missing a single week. We hope you all continue to enjoy these problems and also that this next year we can find more exposure for these problems so students of all levels can push themselves to apply what they already know in challenging ways. **
This week's problem is one of the most challenging we've had for this level and it requires some knowledge of physics concepts. Thank you to MarkFL for submitting this problem for us to use!
A cue strikes a cue ball and delivers a horizontal impulse in such a way that the ball rolls without slipping as it starts to move. At what height above the ball's center (in terms of radius of the ball) was the blow struck?
In order to solve this you will need to know the following:
1) Moment of inertia of a solid sphere: $\displaystyle I=\frac{2}{5}MR^2$
2) Parallel-axis theorem: $\displaystyle I=I_{\text{CM}}+MD^2$
3) Net torque on the ball: $\displaystyle \sum\vec{\tau}_P=F_C(R+x)=I\alpha$.
Here is a hint that explains the situation in terms of approaching the solution:
The first condition of equilibrium yields no useful information because we know nothing of the nature of the friction between the table's surface and the cue ball. We can, however, use the fact that the ball is not in rotational equilibrium and analyze the torque resulting from the horizontal impulse. Since we know nothing about the force of static friction which keeps the ball from slipping, we will choose for the axis of rotation the contact point $P$ between ball and surface. Here the moment arm for the force of static friction is zero. Let $x$ be the requested height above the ball's center, $R$ be the ball's radius, $M$ be the ball's mass, $F_C$ be the average force on the ball, and $a$ be the acceleration of the ball.
Congratulations to the following members for their correct solutions:
1) BAdhi
Solution (from BAdhi):
since at the beginning the ball is at rest,
If the impulse is $P$ and after the impulse if the angular velocity of the ball is $\omega$
$$\begin{align*}Fr&=I\alpha \\
\int Fr\;dt&=\int I \alpha \;dt\\
\left(\int F\;dt\right) \;r&= I \left(\int \alpha \;dt\right)\\
Pr&=I(\omega - 0)\\
Pr&=I\omega
\end{align*}$$
applying $Pr=I\omega$, to the point of contact of the ball and the surface $P$
$$P(R+x)=I_P\omega$$
($R$ is the radius of the sphere and $x$ is the vertical distance of the contact of the cue from the center)
From Parallel axis theorem,
$$I_p=I_0+mR^2$$
when $I_0=\frac{2}{5}mR^2$
$$I_p=\frac 25mR^2+mR^2=\frac 75mR^2$$
$$P(R+x)=\frac 75mR^2 \omega \qquad (1)$$
for globe to not to slip,
$$\omega R = v \qquad (2)$$ where $v$ is the velocity of the sphere just after the contact of the sphere
applying $\Delta I=m\Delta v$ to the ball
$$P=m(v-0)\implies P=mv \qquad (3)$$
from (1),(2),(3)
$$\begin{align*}
mv(R+x)&=\frac 75mR^2\frac vR\\
R+x&=\frac 75 R\\
x&=\frac 2 5 R
\end{align*}$$
Therefore the cue should contact the ball at a length of 2/5 times the radius of the ball above the center for the ball to avoid slipping
(from MarkFL):
The torque on the ball is given by:
\(\displaystyle \sum\vec{\tau}_P=F_C(R+x)=I\alpha\)
Newton's 2nd law of motion gives us:
\(\displaystyle F_C=Ma\)
The moment of inertia, along with the parallel-axis theorem gives is the moment of inertia for the ball:
\(\displaystyle I=\frac{2}{5}MR^2+MR^2=\frac{7}{5}MR^2\)
The relationship between angular acceleration and linear acceleration is:
\(\displaystyle \alpha=\frac{a}{R}\)
and so we find:
\(\displaystyle F_C(R+x)=\frac{7}{5}MR^2\frac{a}{R}=\frac{7}{5}F_CR\,\therefore\,x=\frac{2}{5}R\)
Thus, the cue strikes the cue ball at a height of 2/5 of the radius of the ball above the center.
FAQ: Where was the cue ball struck to initiate rolling without slipping?
Where should the cue ball be struck in order to initiate rolling without slipping?
The cue ball should be struck in the center, or slightly above center, to initiate rolling without slipping. This allows for equal distribution of force and ensures that the ball will not slide or spin on the table.
What happens if the cue ball is struck off-center?
If the cue ball is struck off-center, there is a higher chance of it sliding or spinning on the table instead of rolling without slipping. This can result in an inaccurate shot and may also cause the cue ball to lose speed and not reach its intended target.
Is there a specific angle at which the cue ball should be struck to initiate rolling without slipping?
There is no specific angle at which the cue ball should be struck, but it is important to aim for the center or slightly above center to achieve a successful shot. The angle of the cue stick may also play a role in the cue ball's movement and should be taken into consideration when striking the ball.
Can rolling without slipping be achieved with any type of cue ball?
Yes, rolling without slipping can be achieved with any type of cue ball as long as it is struck correctly. However, some cue balls may have a smoother surface or be made of different materials which may affect the amount of friction and ultimately the cue ball's movement on the table.
Are there any tips for achieving rolling without slipping consistently?
To achieve rolling without slipping consistently, it is important to have proper cue ball control and to strike the ball accurately and with the right amount of force. Practicing and developing a consistent stroke can also help in achieving this type of shot consistently.
