Whether charges can stay inside wires or on the surface of a conductor
In summary, charges can stay inside a wire as long as there is a closed circuit for them to flow through. They stay on the surface of a conductor due to electrostatic repulsion and can move back and forth between the inside and surface, but typically only do so when there are changes in electrical potential or during charging or discharging.
feynman1
435
29
There's an isolated capacitor initially carrying nonzero net charge. Then place the capacitor in a circuit connected with ideal wires (no resistance). Where will the excess charge go? Can they stay in wires or on any surfaces of conductors in the circuit? Electric field needs to be 0 everywhere in ideal wires.
Excess charge distribute on surfaces so that electric field inside conductor is zero.
Related to Whether charges can stay inside wires or on the surface of a conductor
1. Can charges stay inside a wire?
Yes, charges can stay inside a wire as long as it is a conductor. Conductors have free electrons that can move freely within the material, allowing charges to flow through the wire.
2. What happens to charges on the surface of a conductor?
Charges on the surface of a conductor will distribute themselves evenly along the surface. This is known as electrostatic equilibrium, where the electric field inside the conductor is zero.
3. Why do charges stay on the surface of a conductor?
Charges stay on the surface of a conductor because of the repulsion between like charges. The charges spread out as far away from each other as possible, resulting in a uniform distribution on the surface.
4. Can charges move from the inside of a wire to the surface?
Yes, charges can move from the inside of a wire to the surface. This is known as the skin effect, where charges tend to move towards the outer surface of a conductor when exposed to high-frequency currents.
5. What factors affect the distribution of charges on a conductor's surface?
The distribution of charges on a conductor's surface is affected by the shape and size of the conductor, the material it is made of, and the presence of other charges or objects nearby. The larger the surface area, the more evenly the charges will distribute themselves.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
