- #36
Mister T
- 1,457
Differences are also due to position.entropy1 said:But then we get to my point: SR clock differences should be the result of velocity, [...]
Suppose you are flying from Earth to the moon. I have set up beforehand a clock on the moon and I synchronized it with clocks on Earth. You will of course observe my clock running slow, but you will attribute my thinking that your clocks are running slow to an error I made when I did the synchronization.
(Of course, this situation is perfectly symmetrical. I will observe your clock running slow, but if you synchronized the clocks I would attribute your thinking that my clock is running slow to an error you made when you did the synchronization.)
You have to understand this effect, called the relativity of simultaneity, and how it explains the symmetry of time dilation (that is, how each thinks the other's clocks are running slow).
Once you do that you can start understand the answer to the original question you asked. Of course, you have to understand that the two people involved share the same location twice, and can therefore compare the proper time that elapsed between. I recommend that you learn how to draw spacetime diagrams (it's easy) and see that the clock that took the shorter path through spacetime is the clock that shows the smaller elapsed time.
