Mads C
- 4
- 1
I'm making a ventilation system with a fan that will blow air through a 1700mm long pipe that has a 45 degree bent in the middle. I should decide on a pipe diameter of 125mm or 160mm.
Also I need to choose between 3 different fans that has the following specs from the manufacturer:
120mm fan: 234 m³/h - uses 10W
125mm fan: 190 m³/h - uses 16W
255mm fan: 800 m³/h - uses 72W
I'm looking to find the most efficient solution with as much m³/h as possible.
My own guess is that thicker is better for the pipe. Would it make sense to use a 255mm fan on a 160mm pipe - maybe just blowing on 60-70% speed? Or could it make sense to use 2 of the small, energy-efficient 120mm-fans and somehow combine them with one 160mm pipe? Or is it best to choose a fan that precisly fits with the pipe (125mm fan with 125mm pipe)?
Anyone have an opinion of the most sensible solution? And perhaps someone even has a guesstimate of what m³/h I can hope to achieve? Any help is greatly appreciated! Many thanks in advance
All the best,
Mads
All the best,
Mads
