Which Gas Behaves Closest to an Ideal Gas?
In summary, out of the gases hydrogen, nitrogen, chlorine, and helium, helium exhibits behavior closest to an ideal gas due to its lack of attractive forces between atoms. While there may be Van der Waals forces present in all cases, helium is the only noble gas with isolated, electrically neutral atoms, making it the most ideal.
markosheehan
136
out of the gasses hydrogen,nitrogen,chlorine, and helium which shows behviour closest to an ideal gas.?
ive been told the answer is helium because there is no attractive forces between helium atoms. would there not be van der waal forces though.? also would hydrogen just have as little attractive forces aswell?
also because hydrogen has only 1 electron so its smaller. so molecules are more widely spaced therefore its closer toeing a ideal gas. but I've been told helium is the right answer. using my logic it doesn't make sense
Mathematics news on Phys.org
Hi markosheehan,
Yes, there are Van der Waals forces in all cases.
However, Helium is the only one that is electrically neutral.
That's because it's the only one that is 'noble'. That is, the outer valence shell is fully loaded, giving the least electrical interactions.
So Helium is the one with isolated neutral $He$ atoms, while for instance hydrogen forms $H_2$ molecules due to its single valence electron. And those molecules have more electrical properties, since the charge is not divided uniformly. As a result $H_2$ molecules interact more with each other than $He$ atoms do.
Noble gasses (such as Helium) are known for their complete lack of interaction with anything.
That's why historically they were the last group of elements to be discovered at all.
It makes them the closest thing we have to ideal gasses.
FAQ: Which Gas Behaves Closest to an Ideal Gas?
What is an ideal gas?
An ideal gas is a theoretical gas that follows the gas laws perfectly under all conditions. It is assumed to have no volume or intermolecular forces, and its particles are in constant random motion.
Which gas behaves closest to an ideal gas?
It is commonly believed that most gases behave similarly to an ideal gas under certain conditions, but hydrogen and helium are often considered the closest to an ideal gas due to their low molecular weight and lack of intermolecular forces.
What factors affect a gas's deviation from ideal gas behavior?
A gas's deviation from ideal gas behavior can be affected by factors such as temperature, pressure, and intermolecular forces. At low temperatures and high pressures, gases tend to deviate more from ideal behavior due to increased intermolecular interactions.
Can a gas behave exactly like an ideal gas?
No, it is not possible for a gas to behave exactly like an ideal gas under all conditions. However, some gases may come very close to ideal behavior under certain conditions, such as low temperatures and high pressures.
Why is it important to understand ideal gas behavior?
Understanding ideal gas behavior is important in many applications, such as in the fields of thermodynamics, engineering, and chemistry. It allows for accurate predictions and calculations of gas behavior and can help in the design and optimization of various processes and systems.
