Are Einstein's Relativity and String Theory's Gravity Compatible?
In summary: So I think it's easier to work with the geometrical formulation, despite the fact that the geometrical formulation is more abstract.In summary, Einstein's theory of gravity (General Relativity) and string theory both describe gravity, but in different ways. General Relativity explains gravity as a warping of space-time caused by matter, while string theory describes gravity as a force arising from the exchange of bosons, specifically the graviton. While they may seem incompatible, they can both be "near enough right" to be useful and may even be compatible with each other. However, neither theory is considered to be completely "right" and there is still much research and experimentation needed to fully understand gravity.
Joza
139
In Einsteins's relativity, gravity is described as a force arising from the warping of space-time by the presence of matter.
But, in string theory, it is described as a force arising from the exchange of bosons, the graviton, right?
Surely, both cannot be right? Are these compatible?
Sure they can. These are simply two models describing the same thing.
But in fact, we have not done enough experiments to determine which of the two is more adept at describing gravity.
Einstein's theory (General Relativity, or GR) is a classical theory, whereas one of the goals of String Theory is to create a theory of gravity that is consistent with both GR and Quantum Field Theory (which describes all other known fundamental interactions). In that sense GR has to String Theory the same relationship that Classical E&M theory (Maxwell Eqs.) has to Quantum Electrodynamics.
(Actually, a Quantum Theory of Gravity was not one of String Theory's original goals, but rather it just came about as a nice bonus, which is what gives encourages many people to be optimistic about its correctness. Witten has even countered the claims that String Theory makes no testable predictions by saying that, in fact, it predicts the existence of gravity, as described in the classical limit by GR.)
And as far as I know, no one has yet even proposed an experiment that can distinguish between the two, mainly because string theory has not progressed far enough to make generally-accepted experimental predictions that are different from those of general relativity.
I would bet they are both wrong, but so far, nobody has found out why. That's the way science works, in the long term.
Of course they can be compatible. They can both be "near enough right" to be useful, or Einstein's theory of gravity might be a useful approximation to a string theory of gravity, just like Newtonian mechanics is a useful approximation to relativistic mechanics even though we know Newtonian mechanics is "wrong".
Isn't that the one scientists use to send stuff to Mars, etc.?
I tend to look at all three as being 'not right' but still 'not totally wrong'.
None of them (Newtonian, GR, string) are "right". "Rightness" (i.e., proof) is the domain of mathematics, not physics. String "theory" doesn't even qualify as a theory, yet. Mass is axiomatic and gravity has no mechanism in GR, and that's not "right" in the minds of many physicists. Too much detail is also not right, in a sense. Nobody in their right mind would use either string theory or GR to describe the geopotential (http://cddis.nasa.gov/926/egm96/egm96.html), for example.
Quite possibly. But Newtonian mechanics doesn't explain the orbit of Mercury, and it doesn't explain the behaviour of the clocks on GPS satellites. Relativity does explain both of them, to a practical degree of accuracy.
Approximate theories are fine, but if you use them it's a good idea to know what the approximations are.
Being a ME not a research physicist, I don't have a professional opinion on how well GR agrees with experiment - but there are clearly some bits of the jigsaw puzzle missing at the quantum mechanics level.
What scientific theories are not approximations?
It's not so clear that they both cannot be "right". See for example http://xxx.lanl.gov/abs/astro-ph/0006423
A pedagogical description of a simple ungeometrical approach to General Relativity is given, which follows the pattern of well understood field theories, such as electrodynamics. This leads quickly to most of the important weak field predictions, as well as to the radiation damping of binary pulsars. Moreover, certain consistency arguments imply that the theory has to be generally invariant, and therefore one is bound to end up with Einstein's field equations. Although this field theoretic approach, which has been advocated repeatedly by a number of authors, starts with a spin-2 theory on Minkowski spacetime, it turns out in the end that the flat metric is actually unobservable, and that the physical metric is curved and dynamical.
So one can recover most of GR with a theory based on spin-2 bosons. There are a few issues with this approach, though.
The equivalence is only local. GR predicts the possibility of more complex topolgies (wormholes) than a quantum theory does (wormholes, closed universes, etc). So if we see a physical example of such a complex topology, that would support GR, and would suggest very strongly that the geometrical formulation is right. One would have to put any non-trivial topologies into the "spin-2 boson" theory by hand.
There may be other issues as well. The spin-2 theory as outlined is a bit difficult to deal with because it has entities in it that don't transform as tensors.
Related to Are Einstein's Relativity and String Theory's Gravity Compatible?
1. What is the difference between Newton's Law of Universal Gravitation and Einstein's Theory of General Relativity?
Newton's Law of Universal Gravitation states that any two objects in the universe will attract each other with a force that is directly proportional to the product of their masses and inversely proportional to the square of the distance between them. On the other hand, Einstein's Theory of General Relativity provides a more comprehensive explanation of gravity by describing it as the curvature of space and time caused by the presence of mass and energy.
2. How does the concept of gravity differ in the quantum world?
In the quantum world, gravity is described by the Theory of Quantum Gravity, which aims to unify the principles of general relativity and quantum mechanics. Unlike classical theories of gravity, which treat it as a force, the Theory of Quantum Gravity considers gravity as a geometric property of space-time.
3. Can one theory of gravity be proven to be right?
Currently, there is no conclusive evidence to prove that one theory of gravity is right. Both Newton's Law of Universal Gravitation and Einstein's Theory of General Relativity have been extensively tested and have been proven to accurately describe gravity in their respective domains. However, they have not been fully reconciled with each other or with other theories, such as the Theory of Quantum Gravity.
4. Are there any other theories of gravity besides Newton's and Einstein's?
Yes, there are several other theories of gravity that have been proposed, such as the Brans-Dicke theory, the Scalar-Tensor theory, and the Modified Newtonian Dynamics (MOND) theory. These theories attempt to address certain discrepancies in the predictions of Newton's and Einstein's theories.
5. How do scientists continue to study and improve our understanding of gravity?
Scientists use a combination of theoretical models, mathematical calculations, and experimental data to study gravity. They also conduct experiments, such as the recent detection of gravitational waves, to test the predictions of different theories and improve our understanding of gravity. Ongoing research in the field of quantum gravity and attempts to unify it with other fundamental forces also contribute to the advancement of our knowledge about gravity.
  • Beyond the Standard Models
