Which is Greater: $\log_{10}12$ or $(\log_{10}5)^2+(\log_{10}7)^2$?
  • MHB
  • Thread starter anemone
In summary, logarithms and exponents are inverse operations, with the logarithm of a number with base b giving the value of b when raised to the power of a. To compare two logarithmic expressions, the change of base formula can be used. The base used in logarithmic expressions does not affect the comparison, but it is often convenient to use a base that is easily calculable. To simplify a logarithmic expression, the logarithm rules can be applied. The comparison between logarithmic expressions is directly related to the comparison between their corresponding exponents due to the inverse relationship between logarithms and exponents.
anemone
MHB
POTW Director
3,883
115
State with reason which of these is greater?
Mathematics news on Phys.org
Hint:
Extended Cauchy-Schwarz Inequality
My calculator was faster. (Yes)
-Dan
My solution:
Note that by using the extended Cauchy-Schwarz inequality, we have
$\dfrac{(\log_{10}5)^2}{1}+\dfrac{(\log_{10}7)^2}{1}\ge \dfrac{(\log_{10}5+\log_{10}7)^2}{1+1}=\dfrac{(\log_{10}35)^2}{2}$
But we know $35^2=1225>10^3$, so $\log_{10}35>\dfrac{3}{2}$ and therefore $\dfrac{(\log_{10}35)^2}{2}>\dfrac{9}{8}$.
If we can prove $\dfrac{9}{8}>\log_{10} 12$, then we can conclude $(\log_{10}5)^2+(\log_{10}7)^2>\log_{10}12$.
Observe that $10^3=1000>864=\dfrac{12^3}{2}$, so we get $10^9>\dfrac{12^9}{8}$, since $\dfrac{12^9}{8}>12^8$, we have proved $10^9>12^8$, i.e. $\dfrac{9}{8}>\log_{10} 12$.
Therefore, $\dfrac{(\log_{10}5)^2}{1}+\dfrac{(\log_{10}7)^2}{1}\ge\dfrac{(\log_{10}35)^2}{2}\ge\dfrac{9}{8}>\log_{10} 12$.
FAQ: Which is Greater: $\log_{10}12$ or $(\log_{10}5)^2+(\log_{10}7)^2$?
What is the relationship between logarithms and exponents?
Logarithms and exponents are inverse operations. This means that if a number a is raised to the power of b (ab), the logarithm of a with base b (logba) will give the value of b.
How do you compare two logarithmic expressions?
To compare two logarithmic expressions, you can use the change of base formula. This states that logbx = logax / logab. By converting both expressions to the same base, you can easily compare them.
Which base should I use when comparing logarithmic expressions?
The base used in logarithmic expressions does not affect the comparison. However, it is often convenient to use a base that is easily calculable, such as base 10 or base e (natural logarithm).
How do you simplify a logarithmic expression?
To simplify a logarithmic expression, you can use the logarithm rules. These include the product rule, quotient rule, power rule, and change of base formula. By applying these rules, you can condense a logarithmic expression into a single value.
How does the comparison between logarithmic expressions relate to the comparison between their corresponding exponents?
The comparison between logarithmic expressions is directly related to the comparison between their corresponding exponents. This is because of the inverse relationship between logarithms and exponents. If logbx > logby, then x > y. Similarly, if x > y, then logbx > logby.
