Which is Greater: $\log_9 25$ or $\log_4 9$?
  • MHB
  • Thread starter anemone
In summary, the conversation discussed the relationship between $\log_9 25$ and $\log_4 9$, and how to compare and simplify these expressions. The change of base formula was used to rewrite the expressions and make them easier to compare. Using a calculator, it was determined that $\log_9 25$ is greater than $\log_4 9$. It was also shown that both expressions can be simplified using the properties of logarithms. Comparing logarithms with different bases helps with understanding powers and simplifying equations involving logarithms.
anemone
MHB
POTW Director
3,883
115
Which of the following two is greater?
Mathematics news on Phys.org
$9^{1.5} = 3^3 = 27$
$4^{1.5} = 2^3 = 8$
so $\log_9 27$ = $\log_4 8$
or $\log_9 25$ < $\log_9 27$ = $\log_4 8$ < $\log_4 9$
hence $\log_4 9$ is greater
Very good, kaliprasad and thanks for participating!
My solution:
$\log_9 25<\log_9 26<\dfrac{\log_4 26}{\log_4 9}<\dfrac{\log_4 26}{\log_4 8}=\dfrac{\log_4 (26)^2}{3}=\dfrac{\log_4 676}{3}<\dfrac{\log_4 729}{3}=\log_4 9$
My solution:
it should be $\log_9 26=\dfrac{\log_4 26}{\log_4 9}$ (a typo)
FAQ: Which is Greater: $\log_9 25$ or $\log_4 9$?
What is the relationship between $\log_9 25$ and $\log_4 9$?
The two expressions are logarithms with a base of 9 and 4, respectively. They represent the power to which the base must be raised to equal the given number. In this case, $\log_9 25$ is asking "what power of 9 equals 25?" while $\log_4 9$ is asking "what power of 4 equals 9?"
How do you compare $\log_9 25$ and $\log_4 9$?
To compare logarithms with different bases, we can use the change of base formula: $\log_a b = \frac{\log_c b}{\log_c a}$. This allows us to rewrite the expressions as $\frac{\log 25}{\log 9}$ and $\frac{\log 9}{\log 4}$, making it easier to compare.
Which is greater: $\log_9 25$ or $\log_4 9$?
To determine which is greater, we can evaluate the expressions using a calculator. In this case, $\log_9 25 \approx 1.5563$ and $\log_4 9 \approx 1.5$, so $\log_9 25$ is greater.
Can we simplify $\log_9 25$ and $\log_4 9$?
Yes, we can simplify both expressions using the properties of logarithms. $\log_9 25$ can be rewritten as $\frac{\log 25}{\log 9}$, and since $\log 25 = 2$ and $\log 9 = \frac{2}{3}$, we get $\frac{2}{\frac{2}{3}} = 3$. Similarly, $\log_4 9$ can be rewritten as $\frac{\log 9}{\log 4}$, and since $\log 9 = \frac{1}{2}$ and $\log 4 = \frac{1}{2}$, we get $\frac{\frac{1}{2}}{\frac{1}{2}} = 1$. Therefore, $\log_9 25 = 3$ and $\log_4 9 = 1$.
What is the significance of comparing logarithms with different bases?
Comparing logarithms with different bases helps us understand the relationships between different powers and how they relate to each other. It also allows us to simplify expressions and solve equations involving logarithms more easily.
