Which is Larger: \(\int_{0}^{\pi} e^{\sin^2 x}\,dx\) or \(\frac{3\pi}{2}\)?
  • MHB
  • Thread starter anemone
In summary, the integral of $e^{\sin^2 x}$ from 0 to $\pi$ is bigger than $\frac{3\pi}{2}$ because when you replace $x$ with $\sin^2 x$ in the inequality $e^x > 1+x$, it becomes $e^{\sin^2 x} > 1 + \sin^2 x$, which holds for all $x$ except $x=0$. This means that the integral is greater than the integral of $1 + \sin^2 x$ from 0 to $\pi$, which is equal to $\pi + \frac{\pi}{2}$ and simplifies to $\frac{3\pi}{2}$.
anemone
MHB
POTW Director
3,883
115
Which of the following is the bigger?
\(\displaystyle \int_{0}^{\pi} e^{\sin^2 x}\,dx\) and $\dfrac{3\pi}{2}$
Mathematics news on Phys.org
[sp]
Replace $x$ by $\sin^2x$ in the inequality $e^x > 1+x$ (which holds for all $x$ except $x=0$) to see that \(\displaystyle \int_{0}^{\pi} e^{\sin^2 x}\,dx > \int_0^\pi (1 + \sin^2x)\,dx = \pi + \frac\pi2 = \frac{3\pi}2.\)[/sp]
Opalg said:
[sp]
Replace $x$ by $\sin^2x$ in the inequality $e^x > 1+x$ (which holds for all $x$ except $x=0$) to see that \(\displaystyle \int_{0}^{\pi} e^{\sin^2 x}\,dx > \int_0^\pi (1 + \sin^2x)\,dx = 1 + \frac\pi2 = \frac{3\pi}2.\)[/sp]
Small typo, it should read $\pi + \frac{\pi}{2}$ :)
Opalg said:
[sp]
Well done, Opalg!(Happy) And thanks for participating!;)
It is not possible to compare the size of an integral and a fraction as they are two different mathematical concepts. The integral represents the area under a curve, while the fraction represents a numerical value. Therefore, it is not valid to say that one is bigger than the other.
FAQ: Which is Larger: \(\int_{0}^{\pi} e^{\sin^2 x}\,dx\) or \(\frac{3\pi}{2}\)?
What is the difference between an integer and a fraction?
An integer is a whole number, meaning it has no decimal or fractional part. Examples include 1, 5, and -10. A fraction, on the other hand, represents a part of a whole number and is written in the form of a numerator over a denominator. Examples include 1/2, 3/4, and -2/5.
Which is bigger, an integer or a fraction?
It depends on the specific numbers being compared. Generally, a fraction will be smaller than an integer unless the fraction is greater than 1. For example, 1/2 is smaller than 1, but 3/2 is larger than 1.
How do you compare an integer and a fraction?
To compare an integer and a fraction, you can convert the fraction to a decimal and then compare the decimal to the integer. You can also convert the integer to a fraction by placing it over 1 and then comparing the two fractions.
Can an integer be a fraction?
No, an integer cannot be a fraction because it is a whole number and has no fractional part. However, an integer can be written as a fraction with a denominator of 1. For example, 5 can be written as 5/1.
Is it possible for an integer to be bigger than a fraction?
Yes, it is possible for an integer to be bigger than a fraction. This can occur when the fraction is less than 1. For example, 2 is bigger than 1/2.
