Which is the best conductor? Silver or gold? Why?
In summary, the conversation discusses the best electrical conductor between gold, silver, and copper. According to the electrochemical series, gold is considered the best conductor, but the internet shows silver and copper exceeding gold in conductivity. It is suggested that gold may have a better reputation due to its resistance to corrosion, while silver and copper can tarnish and degrade in performance. The conversation also mentions the practical and ideal environments for conductivity, and how plasma and superconductors can also be considered the best conductors. The malleability and hardness of gold are also mentioned as important factors in its usability. Overall, it is concluded that silver is the best electrical conductor in ideal conditions, while gold may be the better choice in practical applications due to its stability
yuganes warman
According to electrochemical series ,gold is the last element thus it is depicted that it is the best electrical conductor.(most of the teachers say that) But according to the internet the best electrical conductor is silver , following copper and gold. Which one is true and why ?
Hi y w. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
That is a good question. Tables show Ag and Cu exceeding Au in both electrical and thermal conductivities.
I'm wondering whether gold enjoys a better reputation because Ag and Cu will both carry surface corrosion products after prolonged exposure to the atmosphere, and this can degrade their performance in lots of practical applications, whereas Au retains its clean shiny surface because it is significantly more unreactive. This means that gold may be the better choice in the long run, depending on the application.
You would not be the first to ask this question, and I'm sure that there is a good answer somewhere.
Can you get them to put that in writing? That strikes me as very wrong.
THE ELECTROCHEMICAL SERIES
This page explains the origin of the electrochemical series, and shows how it can be used to work out the ability of the various substances included in it to act as oxidising or reducing agents.
That sounds more like chemistry, than something to do with conductivity.
According to this website:
Conductivity Of Metals Sorted By Resistivity Conductivity {I've abbreviated the list, btw}
Code:
COND.
SIEMENS/m     MATERIAL
6.287E+07     Silver, Pure
5.800E+07     Copper, Pure
4.060E+07     Gold, Pure
3.538E+07     Aluminum, Pure
The internet is correct.
As to why one metal is a better conductor than another, probably has to do with the "Conduction band" characteristics of the atoms, of which, I have no knowledge.
Sorry!
Likes CalcNerd
Thanks a lot.
This is why sometimes, electrical plugs or contacts will be gold plated. It's pretty much never worth the money to make a conductor entirely out of gold, but a gold plated connector can be nice for the corrosion-resistant properties.
Likes CalcNerd
Gold is superior in applications where reactivity is a concern. Silver, and copper to a lesser extent, are environmentally sensitive.
Likes Fervent Freyja
Silver has the least resistance and is therefore the most conductive, but it will tarnish. Tarnish creates surface resistance which is particularly problematic in applications where "skin effect" is important such as with higher frequencies. Gold is also very conductive but more importantly, it is the least reactive element meaning it will remain shiny and therefore more conductive for the longest amount of time.
Likes Drakkith
Two words are used for conducting properties of a method. one is "best" conducting material and other is "highest" conducting material. First is used in the practical environment and other is used in ideal environment. Gold has superior stability in terms of electrical or thermal conduction at low to high temperature range and harsh environmental conditions. Silver losses its characteristics when temperature varies from 20 to 100 degree centigrade. This is why, gold is best conducting material in practical and silver is highest conducting material at ideal.
Plasma is the best.:-p
best 'material' ??
Do you have any figures for conductivity/resistivity of 'plasma'
Plasma conductivity depends on various parameters. This model will do for now: http://silas.psfc.mit.edu/introplasma/chap3.html#tth_sEc3.5.2
##\eta=5.2\times 10^{-5} \frac{\ln \Lambda}{(T_e/eV)^{3/2}}## Ωm
For example, let ##Z=1##, ##\ln \Lambda = 16##, ##kT = 1000 eV## (about 11.6 million kelvin)
I got a resistivity of 2.6E-8 ohm-m. Which happens to be actually higher than silver (1.59E-8 ohm-m).
But if we up the temperature to 10000eV, we get about 8.32E-10 ohm-m, which is quite a bit lower.
Oops, superconductors beat plasmas pretty handily.
Interesting conversation!
I always believed that Au made the best connector since it inert and is very conductive, but not so in all cases. High contact pressure sealed connectors using Ag are excellent, but not necessarily practical.
An item I did not see here is importance of the malleability and hardness of Au. This detail makes it usable where most other conductors just will not work.
Cheers!
Related to Which is the best conductor? Silver or gold? Why?
Which is the Best Conductor: Silver or Gold?
The conductivity of a material refers to its ability to conduct electrical current. Both silver and gold are known for their excellent conductivity, but there are differences between them. Let's explore some common questions about the conductivity of silver and gold:
Q1: Is Silver a Better Conductor than Gold?
Yes, silver is a better conductor of electricity than gold. Silver has the highest electrical conductivity of any element, making it an excellent conductor. Gold, while also a good conductor, is not as conductive as silver.
Q2: What Makes Silver a Superior Conductor?
The high electrical conductivity of silver can be attributed to its atomic structure and the mobility of its electrons. Silver atoms have more free electrons available for conduction compared to gold, which allows electrical current to flow more easily through silver. This property makes silver the top choice for many electrical applications.
Q3: Why is Gold Also Used as a Conductor?
While gold is not as conductive as silver, it is still an excellent conductor of electricity. Gold is prized for its corrosion resistance and does not tarnish or corrode over time. This makes gold a preferred choice for connectors and contacts in situations where reliability and resistance to oxidation are crucial, such as in electronic components and connectors.
Q4: In What Applications is Silver Preferred Over Gold?
Silver is preferred over gold in applications where the highest level of electrical conductivity is required. These applications include high-frequency radio transmission, high-performance electrical contacts, and in some specialized electronic components. Silver is also commonly used in electrical wiring and cables.
Q5: Are There Any Drawbacks to Using Silver as a Conductor?
While silver is an excellent conductor, it is more expensive than other metals, including gold. This cost factor can limit its use in some applications. Additionally, silver can tarnish over time when exposed to air and sulfur-containing compounds, which may require protective coatings or periodic maintenance in certain applications.
In summary, silver is a superior conductor of electricity compared to gold due to its atomic structure and higher electron mobility. Gold, while not as conductive as silver, is valued for its corrosion resistance. The choice between silver and gold as a conductor depends on the specific requirements of the application and cost considerations.
  • Other Physics Topics
  • Electromagnetism
