Which is the more stable structure?
In summary, it is not accurate to say that myo-inositol is more stable than the other stereoisomers. The wikipedia article is simply stating that myo-inositol will adopt a chair conformation that places the maximum number of hydroxyls in the equatorial position, which does not necessarily make it the most stable. Based on the chair conformations of myo- and scyllo-inositol, it can be argued that scyllo-inositol is the most stable stereoisomer due to its ability to have all hydroxyl groups in equatorial positions.
narutoverse13
Hello!
I've been trying to figure out what the most stable structure of inositol is, but I keep running into conflicting information. I'm not sure whether the most stable conformation is the myo-inositol form or the scyllo-inositol. All of the stereoisomers can be seen on wikipedia at this link under "Isomers and Structures" : https://en.wikipedia.org/wiki/Inositol . In that section in Wikipedia, it says that the myo-inositol form is the most stable. This does not make sense to me though. If you look at the chair conformations of the myo and scyllo forms of inositol, then that doesn't make sense: http://www.tcichemicals.com/en/us/support-download/tcimail/application/125-12.html . You can see that the myo-form has 5 equatorial and 1 axis, but the scyllo form has all equatorial hydroxyls. Since scyllo form has all equatorials, doesn't that make it the more stable structure?
Chemistry news on Phys.org
Myo- and scyllo- inositol cannot interconvert, so there's not much point in comparing their stability. In fact, the wikipedia article writes:
In its most stable conformational geometry, the myo-inositol isomer assumes the chair conformation, which puts the maximum number of hydroxyls to the equatorial position
It is not saying that myo-inositol is more stable than the other stereoisomers. Rather it's just saying that myo-inositol will adopt the confromation that places five of the hydroxyls in the equatorial position (rather than the conformation that places the five of the hydroxyls in the axial position).
Ygggdrasil said:
Myo- and scyllo- inositol cannot interconvert, so there's not much point in comparing their stability. In fact, the wikipedia article writes:It is not saying that myo-inositol is more stable than the other stereoisomers. Rather it's just saying that myo-inositol will adopt the confromation that places five of the hydroxyls in the equatorial position (rather than the conformation that places the five of the hydroxyls in the axial position).
When you say, "myo-inositol will adopt the confromation that places five of the hydroxyls in the equatorial position", does that mean that the most stable isomer will have 5 axial and 1 equatorial hydrogens? Or should it be that the more stable stereoisomer has 6 hydroxyls that are all equatorial? My homework asks to draw all the isomers of the inositols (which I assume is 9 by the number of isomers on wikipedia) and choose the most stable one. Without thinking about interconversion, I just need to know which one of the 9 stereoisomers is the most stable. When they're all converted to chair forms (second link), the scyllo- inositol has all of the hydroxyl groups placed on equatorial positions, making me think that the scyllo-inositol is the most stable. Would I be correct?
The equilibrium that the wikipedia article was referring to is regard to the two different chair conformations that myo-inositol can adopt through "flipping" the ring:
One conformer places five hydroxyls in the equatorial position and therefore is favored over the conformation that places five hydroxyls in the axial position.
Anyway, I would agree with your answer that scyllo-inositol would be the most stable stereoisomer of inositol because it can adopt a configuration where all hydroxyls are equatorial.
Related to Which is the more stable structure?
1. What factors determine the stability of a structure?
The stability of a structure is determined by several factors, including its design, materials used, and the environment in which it is located. The structure's ability to withstand external forces, such as wind and earthquakes, also plays a crucial role in its stability.
2. How does the shape of a structure affect its stability?
The shape of a structure can greatly impact its stability. Triangular and arch shapes are typically more stable than square or rectangular shapes, as they distribute weight and forces more evenly. However, the specific design and materials used must also be considered when determining stability.
3. Is a taller structure always less stable than a shorter one?
Not necessarily. While taller structures may face more external forces, they can also have a more solid foundation and be designed to distribute weight and forces effectively. Shorter structures, on the other hand, may have a weaker foundation and be more susceptible to collapse.
4. How does the center of gravity affect the stability of a structure?
The location of the center of gravity plays a significant role in the stability of a structure. A lower center of gravity increases stability, as it reduces the risk of the structure toppling over. This is why buildings and other structures are often designed with a wider base to lower the center of gravity.
5. Can a structure be designed to be completely stable?
While engineers and architects strive to design structures that are as stable as possible, it is impossible to create a structure that is completely stable. External factors, such as natural disasters, can always pose a threat to a structure's stability. However, through proper design and construction techniques, structures can be made to withstand these forces to a certain extent.
  • Atomic and Condensed Matter
42K
