Which lab equipment should we use to mix a thick solution?
In summary: Cole-Parmer offers.In summary, the team is looking for an equipment that will mix the solution for an extended period of time and have trouble finding a solution to the high price tag of the machine. They have tried a variety of equipment but all have had some problems. The team is considering purchasing a bottle roller machine but is worried about the cost.
Thondyl
Hi all!
We're trying to dissolve a mixture of organic matter with a solvent that is highly volatile. Currently, we have to shake the solution very frequently to ensure the organic matter doesn't settle down on the bottom of the flask.
However, it takes a REALLY long time for the organic matter to completely dissolve and we think we could greatly speed up the process if we can use an equipment that automates the shaking.
The following is a list of equipment that we have tried/thought about but all of them had some problems:
Magnetic stirrer - The organic matter is too thick for the rods to spin properly. The rod quickly moves out of position and spins out of control.
Overhead stirrer - The container must be closed -- the solvent evaporates too quickly and the reaction takes several days to complete.
Orbital shaker - The best option so far but still not very effective. The organic matter is heavy so it settles down on the bottom and isn't really affected by the shaker.
Blender - We haven't tried this but we are afraid the blender might fail since it isn't designed to operate 24 hours for several days at a time. Also, the speed is too great and its also really noisy to leave in the lab.
Any ideas/recommendations on which equipment we should use will be greatly appreciated!
Chemistry news on Phys.org
Soxhlet extraction?
Bystander said:
Soxhlet extraction?
Sorry but could you clarify what you meant? I don' think that's what we're trying to achieve.
We just need an equipment that will mix the solution for an extended period of time.
You're wanting solvent in contact with undissolved material for days without the noise of a shaker (paint cans), or risking mechanical failures; Soxhlet extraction will put hot solvent over undissolved material, leave filtered solution in the boiler, and given an efficient condenser, can be left for days.
Ygggdrasil said:
In what sort of container are you performing the reaction? You may want to consider something like a tube rotator or mixing rotator that will rotate tubes end-over-end (e.g. see http://www.lab-kits.com/image/data/mixer/lab_mixer.jpg or http://europe.labnetinternational.c...roduct-images/Revolver_360_Sample_Mixer_2.png).
We thought of that but it is too small. The solution is in a 1L erlenmeyer flask and it would be really tedious to pour the solution into each test tube.
The solution extremely sensitive to heat so I don't think that'll work.
Heat sensitive slow dissolving gunk ... Have you tried the short bars with the magnetic stirrer?
We did. The bar had a hard time spinning and couldn't stay on the center for very long. The volume is also too great for it to effectively stir even if it did work perfectly.
If orbital shaking seemed most effective, you may want to consider using a baffled flask. These have indentations on the bottom that help to distrub the fluid shaking around in the bottom of the flask. Biologists use these flasks to better aerate microbial cultures, but in your case, it may help mix your solution better than shaking in a standard flask.
Thank you! We'll look into it.
After searching for a while, we found that a bottle roller machine would be perfect for our project: http://static.coleparmer.com/large_images/3620202.jpg
However, when we contacted the manufacturer they told it is going to cost us around $2000!
Why does it cost so much?? $2000 is way too much for an equipment that simply just rotates the bottle around.
Does anyone know where we could purchase this (or a similar) machine for a lower price? Its fine if we have to DIY or do some simple modifications.
Cole-Parmer is the Ford/Chevrolet of laboratory equipment manufacturers/dealers and cheap as you're going to find from that sector. You might try looking in Edmund for lapidary equipment that rolls small jars for rock polishing.
Thanks! We found a couple of bottle rollers at Cole-Parmer's website but they start at $1100 which is still a little too expensive for us. However, the rock tumbler is PERFECT for our needs and the price is affordable too.
You will find a lot of DIY projects on the web with rock tumblers that cost just a few bucks ;)
Related to Which lab equipment should we use to mix a thick solution?
1. What is the best lab equipment for mixing a thick solution?
The best lab equipment for mixing a thick solution is a magnetic stirrer. This device uses a rotating magnetic field to create a vortex in the solution, allowing for efficient and thorough mixing.
2. Can a regular laboratory vortex mixer be used to mix a thick solution?
While a vortex mixer can be used for mixing certain types of solutions, it may not be suitable for mixing a thick solution. The vortex created by this equipment may not be strong enough to effectively mix a thick solution.
3. Is a manual stirrer or an automated stirrer better for mixing a thick solution?
An automated stirrer, such as a magnetic stirrer or a motorized stirrer, is generally preferred for mixing a thick solution. This is because it can provide a more consistent and vigorous mixing action, ensuring that the solution is thoroughly mixed.
4. Can a regular glass beaker be used for mixing a thick solution?
A glass beaker may not be the best choice for mixing a thick solution. The thick consistency of the solution may cause it to stick to the sides of the beaker, making it difficult to mix. It is recommended to use a wide-mouthed container, such as a plastic beaker or a mixing bowl, for better mixing results.
5. Are there any safety precautions to consider when mixing a thick solution?
Yes, it is important to wear appropriate protective gear, such as gloves and goggles, when handling and mixing a thick solution. This is to avoid any potential contact with the solution, which may contain hazardous chemicals. It is also important to follow proper handling and disposal procedures for the solution after it has been mixed.
  • Quantum Interpretations and Foundations
  • Science Fiction and Fantasy Media
  • Feedback and Announcements
  • General Discussion
