Which Metals Can Nickel Reduce?
In summary, nickel reduction is a chemical reaction that uses nickel to reduce metal ions to their elemental forms by donating electrons. Nickel can reduce a wide range of metals and does so by readily donating electrons due to its high affinity for them. However, there are limitations to its reducing abilities, as it cannot reduce more reactive metals like alkali metals. Some common applications of nickel reduction include electroplating, catalysts, and alloy production in various industrial processes.
TT0
211
If a metal was to plate out, it means nickel is a stronger reductant therefore more negative standard reduction potential. 3 metals have a higher standard reduction potential so they will are weaker reductants than nickel. So is D correct?
Cheers!
Yes your answer is correct.
Related to Which Metals Can Nickel Reduce?
1. What is nickel reduction?
Nickel reduction is a chemical reaction in which nickel is used to reduce a metal ion to its elemental form, typically by donating electrons.
2. Which metals can be reduced by nickel?
Nickel can reduce a wide range of metals, including copper, silver, gold, zinc, lead, and iron.
3. How does nickel reduce other metals?
Nickel has a high affinity for electrons, meaning it readily donates electrons to other metals. This transfer of electrons leads to the reduction of the metal ion to its elemental form.
4. Are there any limitations to nickel reduction?
While nickel can reduce many metals, there are some limitations. For example, it cannot reduce metals that are more reactive than nickel, such as alkali metals.
5. What are some common applications of nickel reduction?
Nickel reduction has many industrial applications, including electroplating, catalysts in chemical reactions, and the production of alloys.
11K
