MHB Which method is easier and why?
The discussion focuses on factoring the expression x^6 - y^6 using two methods: difference of squares and difference of cubes. It is noted that applying the difference of squares leads to simpler subsequent steps, resulting in the factorization x^6 - y^6 = (x^3 + y^3)(x^3 - y^3). This method further breaks down into (x + y)(x^2 - xy + y^2)(x - y)(x^3 + xy + y^2). In contrast, using the difference of cubes yields a more complex factorization, although it is still manageable. Overall, the difference of squares is recommended for its simplicity in the next steps.
mathdad
I found the following problem in Section 1.3 of my Precalculus textbook by David Cohen.
Factor x^6 - y^6 as a difference of squares and then as a difference of cubes.
1. Which method is easier and why?
2. Can someone get me started?
Mathematics news on Phys.org
Excellent!
you can apply either way. but next steps become simpler if you apply difference of square
$x^6-y^6= (x^3+y^3)(x^3-y^3)$ 1st term is sum of cubes and second is difference of cubes and you get
$x^6-y^6= (x^3+y^3)(x^3-y^3)= (x+y)(x^2-xy+y^2)(x-y)(x^3+xy+y^2)$
had you chosen difference of cubes you would have got
$x^6-y^6 = (x^2-y^2)(x^4+x^2y^2+y^4)$
factoring $x^4+x^2y^2+y^4 = (x^4+2x^2y^2+y^4)- x^2y^2 = (x^2+y^2)^2 - (xy)^2 = (x^2+y^2+xy)(x^2+y^2-xy)$
above may not be straight forward but doable
Nice work in every sense.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
