Which of the Following is a solution to the differential Equation
In this specific case, both a) and c) are solutions to the differential equation, t^2y" - 2ty' + 2y = 0. So there is no one correct answer, both a) and c) are valid solutions. In summary, for the differential equation t^2y" - 2ty' + 2y = 0, both a) and c) are valid solutions.
Northbysouth
249
Which fot he following is a solution to the differential equation:
t2y" - 2ty' + 2y = 0
a)e-2tt3
b)et
c)t
d) t4
I have attached an image of the question
I tried answer d first:
y = t4
y' = 4t3
y" = 12t2
Plugging in these derivatives:
t2(12t2) - 2t(4t3) + 2(t4) = 0
I also checked with y = t and this solution works as well. So how do I distinguish between which one is the correct answer?
\neq
I think you just made an arithmetic mistake ;)
[tex] t^2(12t^2) - 2t(4t^3) + 2(t^4) = 12t^4 - 8t^4 + 2t^4 = 6t^4 \neq 0[/tex]
In many cases, DE's can have multiple different solutions.
FAQ: Which of the Following is a solution to the differential Equation
What is a solution to a differential equation?
A solution to a differential equation is a mathematical function that satisfies the equation when it is plugged in. It is a set of values that make the equation true.
How do you determine if a particular function is a solution to a differential equation?
To determine if a function is a solution to a differential equation, you must substitute the function into the equation and see if it satisfies the equation. If it does, then it is a solution.
Are there different types of solutions to differential equations?
Yes, there are different types of solutions to differential equations. These include explicit solutions, implicit solutions, and numerical solutions.
Can a differential equation have more than one solution?
Yes, a differential equation can have multiple solutions. This is because there are often many functions that can satisfy the equation when plugged in.
How are differential equations used in real life?
Differential equations are used in many fields of science and engineering to model and predict real-life phenomena, such as population growth, heat transfer, and electrical circuits. They are also used in economics, biology, and many other areas of study.
