MHB Which of the Following is Incorrect Regarding Matrices and Vectors?
  • Thread starter Thread starter Yankel
    Matrices Vectors
Yankel
One last question on these topics, I need to choose the WRONG statement, and they all seem correct to me...
a) If A is a squared matrix for which
\[A^{2}-A=0\]
then A=0 or A=i
b) If A and B are diagonal matrices, then Ab=BA
c) A 4X4 matrix with eigenvalues 1,0,-1,2 is "diagonlizable"
d) The dimension of the polynomials space of order 3 (ax^3+bx^2+...) is 4
e) If two vectors are linearly dependent, then one is necessarily a multiplication of the other
'a' is correct
'b', not sure, I tried one example, it worked
'c' Each eigenvalue appears once, so it's not possible to have an eigenvalue which appears twice with corresponding 1 eigenvector (for example)
'd' Isn't it 4 ?
'e' I think so...
will appreciate your help
Concerning answer a): consider
$$A=\begin{bmatrix} 1 &1 \\ 0 &0 \end{bmatrix}.$$
To underscore a common mistake:
Just because:
$A^2 - A = A(A - I) = 0$
There is NO REASON to believe $A = 0$ or $A - I = 0$.
It is VERY POSSIBLE to have matrices $A,B$ with $AB = 0$ but $A,B \neq 0$.
Any such matrix, of course, is singular.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
