MHB Which of the group axioms are satisfied?
  • Thread starter Thread starter mathmari
    Axioms Group
mathmari
MHB
Hey! :o
I want to check the following sets with the corresponding relations if they satisfy the axioms of groups.
  • $M=\mathbb{R}\cup \{\infty\}$ with the relation $\min:M\times M\rightarrow M$. It holds that $\min (a, \infty)=\min (\infty, a)=a$ for all $a\in M$.
  • $M=n\mathbb{Z}=\{n\cdot a\mid a\in \mathbb{Z}\}$ for a $n\in \mathbb{N}$ with the usual multiplication of integers as the relation.
  • $M=\{w,f\}$ with the relation $A\star B:=(A\implies B)$.
  • $M=\{g\in G\mid \forall h \in G: g\star h=h\star g\}$ for a group $(G, \star )$ with the relation of the group $(G, \star)$ as the relation.
The axioms that we have to check are the following, aren't they?
  1. Associativity : For all $a, b, c \in G$ it holds that $a \star (b \star c) = (a \star b) \star c$.
  2. There is an element $e \in G$ with the property $e \star a = a$ for all $a \in G$. ($e$ is the identity of $G$).
  3. For each element $a \in G$ there is $a' \in G$, such that $a'\star a = e$. ($a'$ is the inverse to $a$).
I have done the following:
  • The associativity is satisfied, isn't it? Do we jusify that as follows?
    $\min (a, \min (b, c)) = \text{ minum of } \{a, b, c\} = \min(\min (a,b), c)$
    The identity is $e=\infty$.
    In this case there is no inverse.
  • The associativity is satisfied, as the multiplication of integers is associative.
    There is no identity and there is not an inverse for each element (for example there is no inverse for the element $n$).
  • Could you give me a hint for this set?
  • Since we have the relation of the group $(G, \star)$, all the three axioms are satisfied.
Is everything correct? (Wondering)
mathmari said:
Hey! :o
Hey mathmari!
You're missing one, which I'd like to call the 0th axiom: the set has to be closed under the operation $\star$.
Furthermore, we require $e \star a = a \star e = a$, since the operation is not necessarily commutative.
Similarly we require $a'\star a = a \star a' = e$.
You're using the usual property of minimum that it is supposed to be associative.
But doesn't this minimum have a special case for $\infty$ so that associativity is not immediately obvious for the cases where $\infty$ is involved?
mathmari said:
  • The identity is $e=\infty$.
Correct.
There is an identity if $n=1$. For $n>1$ there is no identity.
Either way, it's not a group because even for $n=1$ the element $0$ doesn't have an inverse.
I assume that $w$ stands for $\text{Wahr}$? Can we make it $\{t,f\}$ then?
Then it's closed and associative with respect to the implication operator.
But it's not associative.
Can we find an identity $e$ such that for each $A$ we have that $(A\Rightarrow e) = (e\Rightarrow A) = A$?
When is an implication true exactly? (Wondering)
Not so fast.
For starters there is an additional condition, which I like to call to 0th axiom: the set has to be closed under the operation. Is it satisfied?
We can skip associativity since that is indeed implied from $G$.
Is the identity of $G$ also contained in $M$? If so then it will also be an identity in $M$.
Does each element in $M$ have an inverse that is also in $M$?
For the record, since $M\subseteq G$ we have that $M$ is a group iff it is a subgroup of $G$.
To verify if $M$ is a subgroup it suffices to verify if it is:
  • Non-empty.
  • Closed under the operation $\star$.
  • Closed under inverses.
(Nerd)
Ok. And what do we do if no element is the minimum? Or do we consider in that case the usual property? (Wondering)
The identity must be T, or not? Because it holds that $(T\Rightarrow T)=T$ and $(T\rightarrow F)=F$. Is this correct? (Wondering)
About the inverse... There is no such an element, is there? (Wondering)
Do we not get that again that $(G, \star)$ is a group? (Wondering)
Let $e$ be the identity of $G$. Then we have that $e\star h=h=h\star e$, or not? From that it follows that $e$ is also contained in $M$, right? (Wondering)
Let $g\in M$. Let $g^{-1}$ be the inverse of $g$. Then we have that $g^{-1}\star g=e=g\star g^{-1}$, so $g^{-1}\in M$, right? (Wondering)
If no element is the minimum, then we do not have closure, so that M would not be a group.
However, let $a=\infty$. Then what is $\min(a,\infty)$?
That shows that T is a left-identity. Is T also a right-identity?
Closure is indeed given for G. But shouldn't we verify it for M?
Right!
Shouldn't it hold for any h instead of just g? (Wondering)
If $\infty\notin \{a,b,c\}$ then we have that \begin{equation*}\min (a, \min (b,c))=\text{ Minimum of } \{a,b,c\}=\min (\min (a,b), c)\end{equation*}
If $\infty\in \{a,b,c\}$ (let $a=\infty$ then $\min (a,x)=\min (x,a)=x, \forall x$) then we have that \begin{equation*}\min (a, \min (b,c))=\min (b,c) \ \text{ and } \ \min (\min (a,b), c)=\min (b,c)\end{equation*}
Do we show in that way the associative property? (Wondering) About the inverse element: Each element $a\neq \infty$ has no inverse, since $\min (a,b)$ for each $b$ is not equal to the identity $\infty$.
Is is just the left-identity, so there is no identity, right?
Yep. All correct. (Nod)
I am not sure about associativity.
The associativity does not hold: $f\star (t\star f)=f\star f=t$ but $(f\star t)\star f=t\star f=f$, right?
($a\star b$ is defined as $a\implies b$)
To finish it up.
As you already said, we have $e\in M$ since $e\star h = h\star e = h$.
It also means that $M$ is non-empty.
If $g_1,g_2\in M$, then:
$\forall h \in G: (g_1 \star g_2)\star h=g_1\star (g_2\star h)=g_1\star (h\star g_2)=(g_1\star h)\star g_2=(h\star g_1)\star g_2 = h\star (g_1\star g_2)$
So $g_1\star g_2 \in M$, and therefore $M$ is closed under the operation $\star$.
If $g\in M$, then:
$\forall h \in G: g\star h=h\star g \quad\Rightarrow\quad
g^{-1}\star(g\star h)\star g^{-1} = g^{-1}\star(h\star g)\star g^{-1} \quad\Rightarrow\quad
h\star g^{-1}=g^{-1}\star h$
So $g^{-1}\in M$, and therefore $M$ is closed under inverses.
Thus $M$ is a subgroup of $G$ and is therefore a group on its own. (Thinking)
Thanks a lot! (Smile)
