Which of these diagrams represent the same circuit?
In summary, the circuit diagram for B is incorrect because it does not have a potential difference with the battery.
Feodalherren
605
I thought it was A and D because it seems to me that in both cases the current is going splitting into two different paths. Also it seems to me that in A and D the potential difference is the same.
But that's incorrect and I can't understand why.
A and B seems wrong to me because the capacitor is at a different potential.
A and C seems wrong because the resistor blocks the capacitor in C.
B and C seems incorrect because of the resistor blocking the capacitor in C but not in B.
B and D seems incorrect because the capacitor at B looks like it is at a higher potential.
Basically I've ruled out C. The resistor that blocks the battery makes it unique.
I think you are correct in ruling out C. A simple way to see that is the capacitor has been short circuited by the straight wire to its left! No current will ever flow to the capacitor since the current can choose a path with 0 resistance.
I also think your conclusion that A and D are equivalent is correct. But I don't understand why you ruled out B. Why do you think the capacitor is at higher potential? Let's look at the capacitor portion of the circuit. If I draw --||--------------------- is this different than --------------||-------------? Does the length of my (0 resistance) wires matter?
Answer A and D was incorrect but I don't understand why.
I thought that it was at a higher potential because at A the capacitor is parallel with the battery while at B it isn't.
Can you redraw A, B, and D so that they look the same (without, of course, changing anything at any of the nodes) ?
A and B should work. But as I said, it's not the correct answer.
Are you given multiple choice for this problem, or are you asked to provide your own answer?
Also, you seem to think that the capacitor in B is not in parallel with the other circuit elements, why do you think this?
Multiple choice.
And I just noticed that there was an A, B and D choice at the end of the table, and that was correct. Duh.
I thought B was at a different potential because it's not at the same "height" as the battery.
Does height on a circuit diagram matter? What if I flipped the diagram up-side-down, would you say it's at a lower potential then?
Likes Feodalherren
Seems like it doesn't, which clears up a lot of what was confusing me about them. My professor has an outrageous accent and I have a very hard time understanding him. He was talking about how we should treat circuit diagrams as "gravitational potential energy" but I couldn't really understand much more of what he said.
So if I understood this correctly, I select a point where V=0 then go around the circuit and when I get back to that point the sum of all the changes = 0 (Kirkhoff's law)?
Yes, you can start at the bottom left in B, go past the battery and get V go to the top right and pass by the capacitor and you have to get -V from the capacitor so you end up with 0 when you finish the loop. In diagram A you do the same and find that the capacitor also has voltage -V. As long as you don't move past a node, or past another circuit element, you are free to move circuit elements around. Because making a longer or shorter wire does not matter to the circuit since wires are assumed to be resistance-free.
So in diagram B, I can just move to capacitor from being on the top right to the right edge (no node or other circuit element was passed) and you can clearly see that it's the same as A.
Likes Feodalherren
It's common (good practice) to draw circuits so that higher voltage nodes are towards the top of the page, so perhaps that's what he was referring to, however you shouldn't don't take that too literally. Moving a capacitor higher on the page or along a wire (as in the change from A to B) doesn't change anything electrically.
Likes Feodalherren
It's kind of like GPE, but the wires essentially don't exist. The energy doesn't change until you pass through a non-wire element.
It's worth noting that the connections on a schematic are just there to show us how the elements are related. The actual wiring of a physical circuit need not look anything like the schematic.
FAQ: Which of these diagrams represent the same circuit?
1. What is a circuit diagram?
A circuit diagram is a visual representation of an electrical circuit, showing how the components are connected and how electricity flows through the circuit.
2. Why are there different diagrams for the same circuit?
Different diagrams may be used to represent the same circuit because they may show different levels of detail or use different symbols to represent components.
3. How do I know which diagram represents the same circuit?
You can compare the components and connections shown in each diagram to determine which one represents the same circuit. The basic layout and order of components should be the same.
4. Can I use any of the diagrams to build the circuit?
Yes, as long as the components and connections are the same, you can use any of the diagrams to build the circuit.
5. Are there any advantages to using one diagram over another?
Some diagrams may be easier to read or understand, but ultimately, as long as the components and connections are the same, any diagram can be used to represent the circuit.
