Which one of these two statements is wrong ?
  • MHB
  • Thread starter Yankel
In summary: Every set of n linearly independent vectors is a basis for a vector space with n dimensions. This is because the vector space will have at least that many dimensions, and the vectors must span it.
Yankel
395
a. every set of n linearly independent vectors are basis of a vector space with dimension n
b. An invertible matrix is necessarily diagonalizable
they both seems wrong to me, but only one suppose to be.
'a' sounds wrong because the n vectors must also span the vector space
and 'b' because I don't see the relation between invertible and diagonalizable
Which vector space?
n linearly independent vectors span a vector space with n dimensions.
Since the vector space has only n dimensions, those vectors necessarily must span that vector space.
For 'b' you should try to find a counter example.
Can you think of a matrix that is not diagonalizable, but still has a non-zero determinant?
to extend serena statement.
If D is a diagnizable matrix then there exists an invertible nxn matrix P
such that D = $P^{-1}AP$ where A is the matrix with the eigen values of D on its diagonals.
Now take D = $\begin{bmatrix} 1 & 1 \\ 0 & 1 \end{bmatrix}$. whose eigen values are 1,1. Now if D is diagnoziable there would exist a nxn invertible matrix P such that
D = $P^{-1}\begin{bmatrix} 1 & 0 \\ 0 & 1 \end{bmatrix}P$, now 4 $\begin{bmatrix} 1 & 0 \\ 0 & 1 \end{bmatrix}$ is just the identity matrix.
so D = $P^{-1}P = I$, since $D \not = I$, it is clear that D is not diagnizable.
Yet D is invertible Det(D) = 1.
thanks everyone for your answers, it's very helpful.
I still don't fully understand why when the dimension is n the vector must also span.
I will try to look for some further material on it
thanks
FAQ: Which one of these two statements is wrong ?
What does it mean when someone asks "Which one of these two statements is wrong?"
When someone poses this question, they are typically asking for clarification or confirmation on a specific topic or statement. They may be unsure about the accuracy of two conflicting statements and are seeking clarification on which one is incorrect.
How do I determine which statement is wrong?
To determine which statement is wrong, it is important to carefully analyze both statements and look for any inconsistencies or contradictions. Consider the evidence or sources supporting each statement and evaluate their validity. You may also seek the opinion of experts in the field or conduct further research to reach a conclusion.
Can both statements be wrong?
Yes, it is possible for both statements to be wrong. This could occur if both statements are based on incorrect information or if they are both misinterpretations of the same concept. It is important to carefully evaluate the accuracy of each statement before coming to a conclusion.
What should I do if I am unsure which statement is wrong?
If you are unsure which statement is wrong, it is best to seek clarification from a reliable source or conduct further research. Avoid making assumptions or jumping to conclusions without sufficient evidence. It may also be helpful to consult with experts in the field to gain a better understanding of the topic.
Is it important to identify which statement is wrong?
Yes, it is important to identify which statement is wrong in order to have a clear and accurate understanding of the topic at hand. When conflicting statements are presented, it is important to determine which one is incorrect in order to avoid spreading misinformation and to ensure that decisions and actions are based on accurate information.
