Which orbital is lower in energy
In summary, molecular orbitals are formed by the combination of atomic orbitals and can be either bonding or antibonding. Atomic orbitals are the regions of space where electrons are most likely to be found in an atom. Ionic orbitals refer to the orbitals of ions, which are formed when an atom gains or loses electrons. Molecular orbital theory states that the antibonding orbital is of higher energy than the bonding orbital. To learn more about these concepts, it is recommended to refer to textbooks or online resources on atomic and molecular physics, quantum chemistry, and electronic orbitals.
alijan kk
130
Molecular orbital
Atomic orbital
Ionic orbital
I have learned molecular orbital theory, and it says antibonding orbital is of higher energy than bonding orbital.
what are molecular and atomic orbitals?
Chemistry news on Phys.org
Related to Which orbital is lower in energy
1. What is the difference between the energy levels of orbitals?
The energy levels of orbitals refer to the amount of energy required to move an electron from one orbital to another. The lower the energy level, the closer the orbital is to the nucleus and the more stable it is.
2. How do orbitals with different energy levels affect electron behavior?
Electrons in lower energy orbitals are more tightly bound to the nucleus and are less likely to be involved in chemical reactions. On the other hand, electrons in higher energy orbitals are more likely to participate in chemical reactions.
3. What determines the energy level of an orbital?
The energy level of an orbital is determined by its principal quantum number (n). The energy level increases as the value of n increases.
4. Is there a specific order in which orbitals are filled according to their energy levels?
Yes, the orbitals are filled in order of increasing energy level, known as the Aufbau principle. This means that lower energy orbitals are filled before higher energy orbitals.
5. How do the energy levels of orbitals affect the properties of elements?
The energy levels of orbitals play a crucial role in determining the chemical and physical properties of elements. Elements with completely filled low energy orbitals tend to be more stable and unreactive, while elements with partially filled higher energy orbitals are more reactive and tend to form bonds with other elements.
  • Chemistry
